Question about Xerox Office Equipment & Supplies
I have a Xerox copier. First copy comes out OK.
I have a Xerox copier. First copy comes out OK. After that there is a strange squeaking sound and there are white vertical lines in my copies. Tried new toner. Didn't fix. Could it be the drum?
    President:
  • 2,072 Answers
That sounds very much like the problem.
Posted on Feb 08, 2010
Xerox Copier 5328 Paper jams where the baffle located. Goes through but does not come out. is
Sounds like a fuser problem. Also, because this is a very old model, constant heat over time can warp plastic paper path guides which will cause strange jamming. These issues hare sometimes hare to pinpoint. Why not get a new copier?
Feb 13, 2014 | Office Equipment & Supplies
Xerox c118 copy is not centered
Enter diagnostic: press "0" then "Start", enter System settings->CE Settings->MFC->Regist, enter 102 to adjust x-axis or 101 - y-axis, adjustment range x (-24 to 127), y (-72 to 72). 24 bit = 1mm. Good luck
Nov 20, 2013 | Xerox CopyCentre C118 Copier
Copier keep making noise while copying
Do you see any issue with the print quality? If everything is working ok and it's still making a noise call your photocopier provider.
If you dont have one, i work for a xerox partner. Either call or email us and i will get someone to advise you.
Mar 19, 2012 | Xerox CopyCentre C20 Black and White...
Xerox 6250 squeaks when printing
The image unit 108R00591 is known to squeak.
You can also isolate the motors in diags. (Power-on the machine holding the back arrow and the "i" button and scroll to Motors) If any of them squeak then you have another suspect.
Jul 20, 2010 | Xerox Phaser 6250N Printer
Whenever copies are made, or a fax comes in, the machine squeaks very loudly. How can I fix this?
can you say from where the sound comes? If from left side check the drum unit and fixing unit. If from back check if all plates or main motor, or fan are ok.
If from paper tray check for any breakage, paper leftovers,...
Hope that helped
May 13, 2010 | Canon imageCLASS MF6590 Copier
I HAVE A XEROX XC-830 COPIER AND THE FIRST INDICATOR LIGHT ON MY LEFT IS ON. THE COPIES ARE COMING OUT WITH BLACK LINE IN THE MIDDLE.
Sounds like copy cartridge is bad or old. Probably drum. If there's round symbol that's on, that's it....Drum.
Apr 03, 2010 | Xerox 8830 Copier
Xerox 7345 red comes out orange. Performed auto
the wrinkles sound like the fuser, how many copies on the machine? when was the last service? copiers are like cars they need to have there maitenance
Jan 15, 2010 | Xerox Office Equipment & Supplies
Area where final copies come out of machine making
Sounds like the output clutch. Take the top off the fuser area and clean the clutch.
Dec 04, 2009 | Xerox WorkCentre 432 ST Copier
Xerox xc1020
is it a printer/copier?
yes....do both prints and copies off the glass come out black?
yes...probably a problem in the drum/ CRU area
No- prints OK but copies black lift the lid and watch the exposure lamp...does it light up? does it move? Both of these scenarios would usually bring up a fault code, so I would still be inclined towards the drum unit.Pull the unit out and make sure no paper has sneaked up between the drum and the exposure slot, or even into the drum unit. another cause could be a broken corotron wire (very thin wire close to the drum usually behind a grid (charge grid) If it is a customer replacement drum unit (CRU) the charge grid will be built into the unit and will require the whole thing replacing.......
Dec 27, 2007 | Xerox CopyCentre C20 Black and White...
104 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
