Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Insinkerator badger 5 leaks from bottom,which is cheaper repair or replace.
  • 5,568 Answers
The seals are shot and it is probably a point at which it should be replaced since that particular brand doesn't have a great track record and is one typically installed in new homes for its low cost.
Posted on Feb 08, 2010
Insinkerator leaking from bottom
Any leak from bottom part of disposal means replacement.
Copy following link for specific troubleshoot, and replacement steps with tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Nov 05, 2012 | Badger 5 Insinkerator 76037h 1/2 Hp Feed...
How can i tell how old my insinkerator is ?
Hello, W/D here.
Basically, I'd have to say that the date of manufacture isn't really important. The Badger InSinkErators can last a long time, or wear out in a short time. I have replaced a number of them. Some were still in warranty, and some were much older. I would look instead at the performance of the disposer. Check especially for leaks around the bottom, indicating worn seals or bearings, the most common serious problems. When this is the case, it is cheaper to replace the unit than to attempt a rebuild. If the disposer is leaking all the way through the disposer, it may be leaking through the wiring connection cavity, making a shock hazard a real possibility, so trip the breaker before investigating such a leak further.
Best regards, --W/D--
Apr 25, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5 is leaking from bottom of unit... is this repairable? Thanks Chad
If it is leaking from the bottom and not from the top and running down the side then it is only repaiable by replacing the disposal, If it the top leaking and running down the side, then it can be rpaired by replacing the rubber gasket on the top.
Nov 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Our 6 yr old badger 5 is leaking from the bottom. Can I fix it or do I get a new one?
Yes, you need to get a new one. Even trained InSinkErator repair personnel have told me the same. Their service call alone would pay for a new Badger and then some. You have actually done well for it to last a full 6 years.
Sep 08, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: leaking out the bottom...
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I just noticed that my insinkerator Badger 5-75
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
heatman101
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insinkerator Badger 5 plus 5 is leaking from the bottom plate
If you need some part, take a look on amazon, here: Amazon com insinkerator badger 5 parts I bought replacement plate from there.
May 30, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal leak
Don to install a new one.
don't think it is a DYI and by the time you call for service it would be cheaper and use your DIY.
Hope this is a FixYa
Please rate the answer
Kurt
Mar 23, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaks from two locations on my Badger 5, 1/2 hp disposal
These holes are probably due to wear, as they are at about the level of the cutter. In general, residential disposals are not repairable and once they begin to leak, they must be replaced. The Badger series is Insinkerator's budget line and probably has about a 5 year lifespan with normal use.
Dec 20, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
1,493 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
