Question about Lucent 1872 Corded Phone
The phone cuts off after a few seconds when someone is trying to leave a message.
  • Don Friedman Feb 08, 2010
    There were no messages on the system but I pressed delete anyway just to confirm that the memory was empty. Then I removed the cards covering the memory area and depressed what I think is the reset button. I am not totally sure I pressed the right button. I used a paper clip to press a button to the right side of the phone just to the right of the "lower" button.
    I then called this phone and the problem did not go away. And in fact did not record the short message I tried to leave.
    Any more ideas?
    Don
  • 2,200 Answers
The system is capable of recording a message up to 4 minutes long. There are 3 main causes of incomplete messages
1) If a caller leaves a very long message, part of it might be lost when the system disconnects the call after 4 minutes.
2) If the caller pauses for more than 7 seconds, the system stops recording and disconnects the call.
3) If the system’s memory fills up during a message, the system stops recording and disconnects the call.
If you find that this problem is happening with all messages then the problem is with the memory or a corruption of the system and there are two remedies.
1) Individually select and delete old messages in order to free up memory for new ones - to do this simply press delete whilst listening to an old message.
If you want to delete all messages press and hold down the delete button until you hear an announcement that all messages are deleted. This only works if you have listened to all of your messages. If there are new messages on the system it will beep 5 times to indicate that no deletion has occured.
2) If the problem persists you will need to reset the system. To do this;
Remove the directory card and its plastic cover from the memory button area.
You will see the reset button. The button is recessed. Use the end of a paper clip to press the reset button.
Be aware: If there is a problem with the system, pressing the reset button will completely reset the system, and might delete any messages as well as your announcements. You may have to record a new announcement.
Thanks for using FixYa. If the solution works please do leave a vote for it.
Posted on Feb 08, 2010
  • Radio Code Pro
    Radio Code Pro Feb 08, 2010
    The reset button is actually recessed into the body hence the need for the paperclip. The location sounds correct. I would suggest the precaution of recording a new announcement and ensuring that it is attributed to the correct mailboxes - usually mailbox 1 and 2.
    There is a secondary 'announce only' feature on this phone which plays an announcement only but does not record a message - however this is for mailbox 3 and 4 only and is usually accessed from outside via a touchtone phone.
    To record a new announcement.
    Press ANNC.
    Choose the announcement location by pressing select until the appropriate mailbox is displayed (In your case assign it to mailbox 1 and 2).
    Press Record and then begin speaking after the beep.
    When you are finished - press Stop. You should now hear your announcement.
    Try the answering machine again to see if it records.
    If this fails to work try the reset procedure again - hold the paper clip down on the reset button for five seconds or so to ensure a good contact.
    If these steps fail it would indicate a problem with the memory itself I am afraid.
How to fix sms sending problem ? ?
follow this steps and fix it. God bless you
1. Phone's memory is full
2. Power needs to be cycled
1. Try deleting old text messages to make room for new ones.
2. Fix your phone by cycling power:
· Remove the battery while the phone is powered on.
· Leave the battery out for a few seconds.
· Replace the battery.
· Turn the phone on and try to resend the message
If your text messages still won't go through, contact your service provider.
Jul 31, 2013 | Samsung SGH-S5230 Cell Phone
Our voice messages from outside cut off before message is complete. How do we fix this?
How long are they speaking before it cuts them off?
is it 180 seconds? That is the default for IP office, but you did not state which system this phone is plugged into...
Feb 28, 2013 | Avaya 1408 Digital Phone 700469851
People got cut off when leaving their mesage
there is only time to leave a phone number to call back?
Mar 02, 2012 | Televison & Video
Message Indicator Light Continues to Flash
Don't know about other models, but I just called RCA small business phone support (800-511-3180) to find out how to clear the message light indicator on my 25210 2-line cordless phone when it continues to blink but there is no message.
All you have to do is hold down the delete button for a few seconds and it will clear. Hope this helps someone else from going batty!
Feb 12, 2009 | RCA 25414RE3 Corded Phone
Messages are cut off at the end
maybe you havea time limit that it can record for. or maybe it is onthe line you use and not the mahine.
Jul 15, 2008 | Lands Phones
Voice mail - you cannot get your messages at this time due to multiple log ins
Sounds like you were kicked out and still logged in, so when you tried to go back in, it said, multiple logins.
Try power cycling the system.
Jun 03, 2008 | Lucent PARTNER18 Corded Phone
Don't have manual and phone shows "SENT" and ext #?
i want to setting toshiba dkt-2020 code number
May 14, 2008 | Toshiba DKT-2020 Corded Phone
GE Digital Messaging System Model # 29875GE1-B
If I am away from my machine and want to call my answering machine and hear the messages what do I do. Lost my manual.
Jan 07, 2008 | GE 29878GE1 Digital Answering Machine
Lucent 1872 Corded Phone Logo
79 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
