Question about Sport & Outdoor - Others
Will not go into four wheel drive when you engage the switch
Polaris 2008 400ho no four wheel drive. will not go into four wheel when you engage the switch
    President:
  • 4,070 Answers
I would suspect a faulty switch, or vacuum line. On some vehicles, this can be caused by a bad electrical ground, or broken wire leading to the transfer case. there are some tricks too to unlock it before you start replacing parts, put it on drive then hit the brakes then take the reverse and see if it unlocks. if doesnt work then have the switch, vacuum line, electrical grounds be checked.
Posted on Feb 08, 2010
2002 Polaris Sportsman 700 vtwin. Why doesn't 4x4 work?
not sure about that model but other polari I've worked on use electronic hubs to engage the four wheel drive. check the wiring to the hubs or possibly a bad switch.
Mar 23, 2016 | ATVs
Wont go in 2 wheel drive but switch works light come on dash ?
2004 Sportsman 700 AWD not working..... - Polaris ATV Forum
www.polarisatvforums.com > ... > ATV Repair and Maintenance
Feb 18, 2013 - Go Back · Polaris ATV Forum > Polaris ATV Technical Discussions > ATV ... AWD wont engage. 2. The instrument / speedo works. 3. The AWD switch is ...Polaris ATV Junkie! .... four wheel drive not working polaris sportsman. Won't go into 4 wheel drive
Feb 1, 2013
4 wheel drive not working
Nov 13, 2011
2004 700, 4WD engages by itself
Oct 28, 2011
4wd is stuck on
Dec 3, 2009
More results from www.polarisatvforums.c
Nov 29, 2015 | Polaris 2004 Sportsman 700 Twin
WHY WON'T FOUR WHEEL DRIVE ENGAGE AFTER SWITCH IS TURNED ON?
Which ATV, year, model, etc? Need more Information when it won't engage.
Jun 27, 2014 | Polaris ATV
I have a 2004 polaris magnum and it wont go into four wheel drive, the light is on, i have power where the two wires go into the housing .
ok my 325 magnum wouldnt go into four wheel drive and now only one wheel will drive if it even catches now what should i do?
Jul 29, 2012 | Polaris ATV
I have a 2001 Polaris Scrambler. One of the front wheels stays engaged when the machine is switched into 2-wheel drive. Any ideas?
check the wires that come out of the hubs and make sure they did not get snaged on somthing and torn apart
Dec 28, 2010 | Polaris ATV
The 4-wheel drive will not engage on my 2005 sportsman
jack up again and with it running in park or neutral move switch in and out of 4 wheel and listen 4 the actuator to move if it sounds like its binding or humming or does nothing if binding un bolt from front end possible and check if actuator rod is bent or needs lube alot of times the actuator needs to be cleaned and lubed if their is nothing no sound or movement test actuator if shorted damaged repair or replace as necessary
Jan 25, 2010 | Polaris 800 Twin Sportsman Ride on Toy
I have a 1997 425 magnum 4x4 and am having 4 wheel drive trouble
I had the same trouble , I bypassed the switch in the gear shift box .
Oct 13, 2009 | Polaris ATV
Sport & Outdoor - Others Logo
83 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
