Question about Hisense Televison & Video
I DON'T HAVE THE REMOTE CONTROL TO THE TV AND IT IS LOCKED. I'VE TRIED USING A UNIVERSAL REMOTE BUT EVEN THIS DOES NOT WORK
  • 566 Answers
Hi sharrelson
I`m gonna help you with your problem , but first could i have the brand name and model number of you tv set?
Posted on Feb 08, 2010
Nikai japan ntv2190stf no working remote control
To open its child lock, you might have its original remote control. Try these methods. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability.
Dec 01, 2013 | Philips Magnavox 27MS343S 27" TV
Ingot my Philips remote programmed on my tv and DVD player. It works but when using DVD player the buttons don't function as its proper function. For example the play button puts the tv on mute,
It is a common problem with any universal remote controls. Try an other code for your device. Select one code which has maximum functionality. Than is the only thing have to do.
Sep 21, 2012 | Philips SRP4004 Remote Control
My Phillips HTS3400/37 Home Theater System came with a remote control, as usual, but it just has stoped working.. I've been trying to make it work by replacing the batteries and it still appears to be...
Try this first on the original remote. Insert the batteries backward and make sure that they make contact with the terminals in the remote control(stick a piece of metal in there to make sure all the posts make contact), then take them off and install them correctly and see if it works, it's a long shot but i've had some luck using this method. now, for the question regarding if the new remote will work, well, i couldn't find the correct code for your receiver using the RCA universal control. The receiver brand(Phillips) is not listed so it probably won't. Here's the RCA control's codes. Just copy and paste the link. http://www.remotecodelist.com/remotes/rca/rca_rcu404.html
Aug 23, 2011 | Televison & Video
My 502 Apex remote stopped working,can i use a universal remote instead and if so,what code do i use?
It's always "hit or miss" with universal remotes. You never know which ones will work with your devices, and if the remote will control your device's features even when you've managed to make a connection. Why not purchase an Apex remote instead?
http://www.replacementremotes.com/APEX/Buy-RCNN131-Digital-TV-Tuner-Converter-Box-Remote-Control.html
Jul 22, 2011 | Televison & Video
I lost my remote control tv-dvd thrutech model t2000d .what is code i can use universal remote conrol
U tries those codes that came with ur universal remote owner manual codes for ur tv model already.Those codes don't work for ur tv.Return the universal remote,because any codes people give will not work either.Try website like Remotes.com to buy the tv original remote.
Jun 09, 2011 | TruTech T2000D TV
My panasonic tv dvd vvcr combo remte rplacement i have tryed universals remotes but they don't work
Return the universal remote,if all ur tv universal codes of ur tv on the owner manual,don't work.Try website like Remotes.com to buy the tv original remote or very close capatible to it.Yes,it cost double even tripple the prices of any niversal remotes,but these remotes are 100% it will work with ur tv,because it the same or compatible as a orginal remote would.
May 31, 2011 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
I have a soniq 42"
Ah, the old universal remote isn't so universal anymore is it? Most "universal" remote controls were designed for the old tube type television sets. There are some seriously nice universal remotes for new flat screen TV's, but most of them are pretty pricey. The only reasonable flat screen universal remote that I've found (that actually works) is the Vizio HDTV Universal Remote. It's about $25, and believe it or not ... Wal-Mart carries it in the store.
May 16, 2011 | Televison & Video
DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 17, 2010 | Universal Remote Control DIRECTV Universal...
Can,t be able to turn my tv set to video mode
try some universal remote controls!
Dec 05, 2007 | Televison & Video
Televison & Video Logo
35 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
