Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Cause of not enough memory
Trouble shooting for not enough memory.
    Guru:
  • 239 Answers
Well you must upgrade your RAM memory
Posted on Feb 08, 2010
When i started my camera it was saying that out of memory why?
Are you sure you have placed a memory card? the internal memory is not enough to save several pictures. Are you sure you did not switch the memory card to the lock position?
If you have a new card, did you format the card in the camera?
All causes for your camera to say "out of memory"
You also could check if the contacts of the memory card are clean and shiny. Only clean with a dry cloth if the look dull. Sometimes just a little bit of dust on one of the contacts of the memory card can cause the same trouble.
Dec 31, 2013 | Nikon COOLPIX Cameras
Memory error test on Gateway 509ge
Thi sis not a problem ..but it is a common issue ..If it says it has 4 G and 3 of them usable ..it means this is either the supported or the maximum needed for your system ..In case you install something it will use the rest for it if needed.Usually there can be another thing too ..If you have an on-board video card ..check the settings in bios cause it may be transferred for the video function ..(the rest of the memory , this is happening when you default the bios ..and it has enough memory to get it from .)
Anyway ..like I said ..even if it is the max allowed ..it may not be the maximum supported..many boards does not supports the maximum on slots ..Older versions even made boot issues on the max ram was installed .
try to take a look in bios settings (advanced settings ) ..and under the on board vga ..see the amount of ram memory allocated , and if you want that memory ..change it ..If you only wanted to know why ..and you are satisfied with 3 G ..and the rest to function for the video card ..just let it be ..
I also suggest to reinstall the operation system if you upgraded memory ..it will assure the best functionality ..
Dec 23, 2011 | Gateway 509GE PC Desktop
The screen is blue and says beginning to dump physical memory
Windows has detected a serious programming-error, and cannot continue to run. Turn your computer off. Turn your computer on.
The next time that you connect to the Internet, Windows will send the "dump" of your computer's memory to Microsoft, so that they can trouble-shoot the cause of the problem, and try to fix it.
Aug 18, 2010 | IBM ThinkPad T22 2647 Notebook
AC Not coming out of vents enought to cool
First thing you should do is check/change your air filters and check the indoor coil and make sure they are clean. If that doesn't make a difference then check your fan and see if you think it is running fast enough. A weak capacitor can cause a fan to run slower. Also check the fan and make sure it is clean. Let me know if you need more help.
Jun 02, 2010 | Heating & Cooling
1993 chevrolet caprice power door locks will not work,
the auctuators get worn out which do not move the lock fully
a rubber grommet at the end of the actuator wears down or falls off causing this problem
Mar 11, 2010 | 1993 Chevrolet Caprice
Trouble booting, doesn't respond when I plug ipod or kindle in, seems to get stuck & goes through start up trouble shoot
have you checked you itunes version and also that your system has enough memory to run the application. This is not total memory but you need to know how much available memory you have free for itunes to run. I have seen this issue occur from too low memory on computers.
Feb 02, 2010 | E-Machines eMachines Desktop PC
Having trouble with my camer shooting slow between pictures
You might have a USB virus or spyware infection in the memory card. I suggest you have Kodak develop the pictures then wipe the memory card clean. And the pictures might be dark because of the camera settings and or the development quality. Try resetting the camera. Hope this works.
Jan 27, 2009 | Canon EOS-5D Digital Camera
Webcam freezes
How much memory do you have installed in your computer? I beleive you need to install more memory so the camera will work. This is a common problem with computer that don't have enough memory.
Nov 10, 2008 | Logitech Webcam
Shooting/playback mode switch
in the end it was my memory card which suddenly went faulty.after formatting it, (see above added comment) it worked for some pictures then i switched to playback and this time it said memory card error and shut down. well if it would have said this in the first place would have saved a lot of trouble i almost threw the thing away.(the camera) so i puts a new card inside and its working like new, all the playback i can handle. goes to show its not always as bad as it looks with a little patience.....merci
Feb 27, 2008 | Canon PowerShot A520 Digital Camera
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
21 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
