Question about Panasonic TH-37PE30 37 in. Plasma Television
TH-37PE30 - DVD picture now lousy (herringbone?)
DVD player ok on another TV: tried another DVD player - just as bad. Switched SCART socket no better. Changed SCART lead no better. Disconnected all other boxes, no better. TV picture analogue and digital ok, satelite and memory card inputs ok. I am confused!
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 88 Answers
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
Posted on Feb 08, 2010
How do I connect to tv there is nothing on the screen from the DVDs player
It depends on your connections for one thing. I did find this piece of information on the DVD player:
"One thing they do not state (in the manual) is that if you are playing it through your Scart socket to your TV. Your TV's Scart socket must be PAL60 compliant".
If they both have HDMI sockets I would get a HDMI cable and connect via that. You will also get a better picture than a scart.
If you are using a scart the connector can also become faulty either inside or a faulty pin so check that too.
Dec 14, 2014 | Alba DVD-108 DVD Player
Sound but no picture
Could be several things. Suggest you check the scart connection to the TV. Is it in the right socket? Is it fully plugged in? Have you selected the right input on the TV? Try a different Scart lead if you have one.
Oct 17, 2012 | Televison & Video
I need to know how to hook my DVD player to ,y Samsung TV. I have it hooked up and have a picture but its in black and white.
look on the back of the television and the DVD player, there should be a SCART socket and/or red, white and yellow AV sockets, either use a SCART lead and connect it to the SCART on the DVD player and the TV.Or use an AV lead with 3 auxiliary shape connectors and match the colour of each connector with the female sockets on both the TV and the DVD player instead of using the other component connections.
Nov 29, 2011 | Hitachi Televison & Video
When I switch on my dvd even the set up page is in black and white. Originally I was getting no picture so I made sure everything was plugged in. Then I got the black and white.
Check the scart cable , try connecting it to another scart socket on the tv. I would even change the scart lead to make sure its ok. I have had loads of similar problems like that caused by scart leads faulty or connected to the wrong socket.
pete.
Nov 27, 2010 | Philips DVDR3380/05 DVD Recorder
The picture is blue when I play a dvd. I recently connected it to a new Vizio TV. The other tv it was connected to gave us a good picture.
Check your connections for faults, also some connections on TV's are for RGB inputs, so you might have to try another connector or if you can switch the DVD's output to RGB etc.
Apr 04, 2010 | GoVideo DVR4000 DVD Player/VCR
Hooking up wii and dvd to tv. i have Direct TV, a DVD player and need to hook up a Wii console. i have the direct tv DVR connected to the DVD player by coaxial cable and the yellow/red/white cables...
does your tv have scart sockets?
if so you can buy this adapter that on one side is the scart socket and the other is the yellow red white sockets
something like this
http://cgi.ebay.co.uk/Switched-SCART-Adapter-Red-Black-Yellow-RCA-Socket_W0QQitemZ260520047480QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3ca8347378
Dec 30, 2009 | Nintendo Wii Console
UMC 19in TV with built-in DVD player - model L19/7TCD
Try connecting earphones or headphones to the 3.5mm Headphone socket on the TV and check this works correctly, i.e hear TV when watching TV, hear DVD when watching a DVD etc.
If all is OK, purchase a 3.5mm Jack to L/R Audio/Phono cable. Connect the 3.5mm jack in to the headphone socket on the TV and connect the red/white phone ends to the 5.1 surround system.
It should solve it. SCART out is not always live in all sources so is not a reliable way to connect.
May 22, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
CANT GET ANY SOUND AFTER CONNECTING THE DVD PLAYER.
have you plugged the leads to audio in on the tv? if it as front sockets us them they are input only some on the back are output.good luck .farr64
Apr 29, 2009 | JVC TH-C3 System
How can i watch dvds on this old sanyo tv?
does your tv have a scart socket or is it pre scart, if it does, and you connect the dvd player via the scart then the tv should auromativally switch to av when the dvd player is switched on. failing that, if you have no scart, then the only way you can watch dvd is by connecting a flylead from dvd player to tv, (take out antenna and put it in that socket) and then start a search if you can, normally the buttons for this are behind a flap somewhere on the tv. if you have no scart or a way of tuning tv, then i dont think you can watch dvd through that tv
Sep 06, 2008 | Sanyo DS24205 24" TV
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Panasonic TH-37PE30 37 in. Plasma Television Logo
116 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
