Question about Toshiba Satellite A45-S130 Notebook
Why is cooling fan making weird noises - Toshiba Satellite A45-S130 Notebook
    Problem Solver:
  • 9 Answers
Depends on what the weird noise is...kind of a squeak? Fan bearing are going out....clicking or dragging sound? the fan blade is hitting something....
Posted on Feb 08, 2010
My outside unit is making a loud weird noise but the inside unit is working completley fine it is 7yrs old now
the outside unit is where it all happens. That is where the compressor is and its cooling fan. The inside unit is just an evaporator, a bit like a car radiator and a fan. The inside unit is protected by the room, the outside unit is in the rain, snow and wind.
You need an AC engineer.
Feb 01, 2016 | Heating & Cooling
The fridge make weird noises some days. Cooling is good, freezer also works well. My concern is if those noises are prelude to a major damage.
This really depends on the type of noise. If you hear a gurgle type noise while running this is usually normal from the refrigerant pumping through the tubing. Fan type noise blowing air in the freezer section is also normal but if it sounds link the fan is rubbing or grinding you need to look into that noise. Also a similar fan down near the compressor area in the lower back section. A low hum from the compressor while running is normal. If you have and icemaker--water running noise about once per hour for around 10 seconds is all normal while the icemaker is filling. Dropping noise from the cubes falling into the bucket is also normal about once per hour. Hope this helps.
Jun 10, 2015 | Refrigerators
My 2004 t&c 3.8 is making a weird sound like a
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make wierd noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
The fan is making a weird noise and when i open the door it stops but when it stops in makes a loud noise and the temp on the fridge wont stay down but the freezer is fine what is the problem
You have a twin cooling unit and the refrigerator fan is getting clogged up with ice possibly due to a defrost problem. You will need to remove the back wall panel of the refrigerator to access the evaporator fan motor and clean it out of the excess ice buildup. Check the defrost circuits and also the defrost drain to make sure it's clear.
Jul 20, 2011 | Samsung RS2630SH Side by Side Refrigerator
This evening, my Dell Inspiron 1521 laptop started making noise from the cooling fan area. What does this mean? Does it need to be replaced?
It could. First thing you should do though is clean the fans out with some compressed air.
Make sure the laptop is off and you're outside. I usually use two cans at once for best results. If you still get weird noises especially screeching then the bearings are going out and you can either grease up the old fan (band-aid fix) or swap it out with a new one.
Hope this info helps and best of luck!
Jan 13, 2011 | Dell Inspiron 1521 Notebook
My air conditioner makes a weird noise when I turn the fan on and it will not blow cool air.
will the fan run? Is the air warm, is there no air? it won't cool if the fan won't circulate air across the cooling coil. You may have a fan problem
Oct 07, 2010 | 2002 Subaru Outback
My air conditioner is making a noise and leaking!
mcdevito75 here, Have your A/C looked at by your local A/C repair shop. Sounds like the compressor is makeing the noise (expensive repair if so)
Jun 22, 2010 | Goldstar KG6000R Window Air Conditioner
Sorround sound switchboard lit up and quit working.
If the fan is making weird noises there is either something wrong with the bearing or it has ingested something.
Maybe you could look, listen closely and determine which it is. If it's foreign matter you may be able to extract or vacuum it out. If it's just bearing noise, you have to decide how bothersome it is and if a shop visit is justified. A clog is BAD because the fan is protecting the unit from high temperatures.
Feb 17, 2010 | RCA RTD300 System
Toshiba Satellite A45-S130 Notebook Logo
330 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
