Question about NetGear WGR614 Wireless Router
WGR614. I simply moved desktop, router and modem to another outlet, same room. Wireless connection to notebook no longer working. I have reset router. Wireless is being detected but cannot connect.
  • 3 more comments
  • rspender Feb 08, 2010
    You've got to be kidding me. The signal is getting out to the notebook. I cannot log onto the signal that has excellent strenth.
    Unplugging and waiting has been done several times.Could we please fast forward thru the baby steps. If you dont know, just say so. I would like a refund to my credit card, unless you have something a little more helpfull.
  • rspender Feb 09, 2010
    still not working. signal is excellent but cannot connect.
  • rspender Feb 25, 2010
    Issue is resolved by help of anandg27. thank you so much!!
  • 1,272 Answers
Hi, please perform the below steps to configure the router:
RESET:
At the back of the router you will find a small tiny hole (which says restore to factory default settings). Press the button with the help of a paper clip and hold it down for 30 seconds. After 30 seconds, please release the button and power off the router for 5 seconds then power the router back.
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
Once online on the main computer connected through the router. Perform the following tasks to configure the wireless connection:
On the router settings page
1. Click on wireless settings from the left menu.
2. Select security options as 'WEP (Wired Equivalent Privacy)'.
3. Set the 'Authentication Type' as 'Automatic'.
4. Set the 'Encryption Strength' as 64-bit.
5. In Key 1 type a 10 digit number.
6. Apply the settings.
Please perform the following steps on your XP wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight thee SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button.
9. You should have successfully established a wireless network connection.
Hope the above steps allows you to resolve the issue
Posted on Feb 10, 2010
  • Anand Gupta
    Anand Gupta Feb 17, 2010
    Is the issue resolved?
  • Anand Gupta
    Anand Gupta Feb 25, 2010
    Glad to assist you. Please rate my solution with 4 thumbs up. It will boost my morale to provide assistance to other users in need.
    Cheers!!!
  • 10,865 Answers
Hello. Click on your start button on your laptop and then click on "connect to" . That should permit you to access the protocol as if your laptop was brand new to your network. Regards, Joe
Posted on Feb 09, 2010
  • 11,896 Answers
Since everything is setup and connected, just unplug the router itself from power cord for 10 full seconds, then plug back in, wait a couple minutes and you will be good to go.
Posted on Feb 08, 2010
  • Nate Stansfield
    Nate Stansfield Feb 09, 2010
    You are supposed to unplug and plug in modem first, then as it goes back on, then do the same to your router.
    Another thing you may want to do is renew your ip address on the pc, Go to run, type ipconfig /release, then ipconfig / renew.
    Or go to back of router and modem, find the pin sized reset button, press it in for 5 seconds and release.
    You can enter your routers configuration settings by opening up a web page, then go to address bar and type 192.168.1.1 and hit enter. Then check all your settings to see if everything is set to Open Nat
  • Nate Stansfield
    Have you tried to set up a home network on your computer, or set connection settings making sure everything is set to automatic. I would try that as well.
    President:
  • 4,070 Answers
Good day, try moving the router and hopefully you find a good signal that the pc can connect. hope this helps, have a nice day
How to remove battery from Motorola SB 5120 modem. I have cable with Charter - my modem and router are connected to my internet ready LG TV. I called Vizio (my router) to find out why I no longer have...
Did you do a reset of the Modem ? If not, look at the rear panel, there is a little button. Press it for a few seconds, you should notice the LEDS on the from panel switch off or flash. Release the Reset button and wait for the LEDS to light up normally again.
You may need to call vizio to reactivate the modem, but it should correct your WiFi problem.
Let me know if this helped.
May 05, 2011 | Arris SURFboard SB5120 Modem
I only have one PC in my house and it's not in the same room where the cable outlet is located. Right now I have a very long coax cable running from my cable modem to the cable outlet in the other room. Is...
Purchase either a USB stick that adds wireless capability to your laptop/desktop, or purchase a PCI wireless adapter-card for your desktop, and install it.
Then, you can move the cable-modem much closer to the cable-outlet, and then connect the cable-modem to a newly-purchased wireless-router ($20 to $70) to receive/transmit over your in-home wireless network.
Jan 24, 2010 | Gateway GT5654 Desktop PC
Need my wep code
the WEP code was set either by you during the setup of the wireless modem, or by the manufacturer. If you set the code and cannot remember it, try resetting the modem back to its factory defaults, the manual for the modem will tell you how to do this. If you no longer have the manual, go to the netgear website and download a manual through the support portal.. Don't be tempted to leave wep turned off, without it, anyone can access your network and your internet connection, steal your identity, bank details etc or simply use up your download limits..
Dec 25, 2009 | NetGear WGR614 Wireless Router
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Netgear WGR614 internet light not coming on
Hi there.
Reset the wireless router by removing the power cord from the back of it for 30-60 seconds, then plug the power back in wait for 2 mins then try to reconnect again.
If you get no joy please post back for aditional advice.
Good luck and thanks for using FixYa!!
May 11, 2009 | NetGear WGR614 Wireless Router
Internet access not working on desktop thru Netgear WGR614 router
Make sure your desktop doesn't have static IP address. Go to Network Connections, Properties of Local Area Connection, Internet Protocol > Properties. Select Obtain IP Address Automatically and Obtain DNS Servers Automatically. Apply the changes and restart the computer.
Jan 18, 2009 | NetGear WGR614 Wireless Router
NETGEAR wgr614 cable wireless router
have you tried to follow the manual chapter 3, page 3-1 ?
If you lost your manual you can find one here:
http://kbserver.netgear.com/pdf/wgr614v6_ref_man_20Apr05.pdf
One of your computers can go online because its using a wired connection to the router, but the wireless clients cannot access the connection - is this right?
Then you only need to setup the wireless part in the router.
Mar 07, 2008 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | NetGear WGR614 Router
NetGear WGR614 Wireless Router Logo
52 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
