Question about SmartDisk FireLite 80 GB Hard Drive
Have about 25Gigs data on Firelite and now says not formatted....how can i retrieve my data
  • SmartDisk Master
  • 13,433 Answers
Unfortunately, you may have to use a data recovery software, if the software is unable to recover your data then possibly the drive has failed, it would need to be taken to a costly data recovery service to get your files back if you really value them and then the drive replaced with another one, If it does not function after it has been formatted, that would indicate that the drive is faulty. I personally use file scavenger http://www.quetek.com/prod02.htm you can take the demo / trial and do a scan on the drive with it, if it finds your files, then they can be recovered, if not, then don't pay for the program, it most likely can't recover anything and your drive might be faulty.
Posted on Feb 08, 2010
Hard Drive RAW System
Run diagnostics on the drive it may be failing. If it's ok you can try to reformat it from Windows Disk Management.
Or if you need to recover data for remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 11, 2012 | FireLite (USBFLB80) Hard Drive
What Windows-compatible "backup" software can
You can format it directly from Windows XP going in My computer then right click on your drive icon and hit format. Don't change anything in the fields but put a check in quick format.
For your backup needs, Acronis are making very good data management softwares.
Feb 10, 2011 | Verbatim 160GB USB FireLite: The "drive...
External hard drive not recognized
where can i find the software for my smartdisk firelite 160gb
Dec 18, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
New computer won't recognize my Firelite, works on old computer
You need drivers for USB, if you remember when you bought smartdisk you got the installation disc, that you now need for a new computer.
Oct 31, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
PowerBook G4 does not seem to recognize. (Worked well on previous Apple lap top)
If your Firelite SmartDisk was formatted for a PC, and you are using the Mac side of the G4 it won't. They use a different format scheme. Need to load Parallel, bootcamp, or another virtual PC program, and then Windows. Using that it will recognize it.
If you know another Mac user that is using both sides (Mac and Virtual PC) is a quick way to retrieve data to move it. Be careful reformatting the FireLite. There are some more complex ways. Hope that this helps.
AAirwolf
PS: I use a 160GB FireLite on my G4, MacBook Pro as well as my Tower and notebook PCs.
May 24, 2009 | FireLite (USBFLB80) Hard Drive
External hard drive does not display icon in My Computer
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Mar 03, 2009 | Verbatim 160GB USB FireLite: The "drive...
My SmartDisk 80 gb FireLite hard drive says it is full but it is empty. What could be the reason for this and how would I format it? I use a Macbook pro. I dont want to have to buy a new external...
You will receive an error message when copying a file larger than 4GB to the hard drive if the drive is formatted FAT32. The FAT32 file system has a file size limitation of 4GB. You may also receive an error when backing up to the hard drive using backup software. To correct this problem you will need to format the drive to NTFS. If you are using Windows ME or 98SE, you will not be able to use NTFS.
There are some products that do not support the NTFS files system or changing their file system. If you own a FlashTrax/FlashTrax XT/FotoChute/PhotoBank/USB FireLite XPress, you cannot change the format of the drive to NTFS. It must be kept as FAT32 in order to operate properly. If you are using SOHO NAS via ethernet, do not format it to NTFS. If you have any questions, please contact technical support before you format the drive.
Warning: Formatting a hard drive erases all data from the drive. Please backup any data prior to formatting the hard drive.
To format to NTFS, open My Computer.
1.Right-click on the Verbatim hard drive, left-click on Format.
2.Select NTFS as the File System.
3.Place a check in Quick Format.
4.Click Start.
Once the format completes, you will be able to copy files larger than 4GB to the hard drive.
Feb 03, 2009 | SmartDisk FireLite 80GB 400Mbps FireWire...
Firelite wont mount on my computer
look at its format, (NTFS) or (FAT32)? and check the DRIVER for the hdd to see if it has any complications or errors, this is easyest fixed by deleting the HDD driver in Device managment and then restarting the computer. good luck.
Oct 09, 2007 | FireLite (USBFLB80) Hard Drive
Smartdisk firelite won't be recognized on desktop-will on laptop
You have not said what system your computers are wroking under I would think your Sony is XP/2000 But the Dell is Win 98 - An I right? IF this is the case it means the drive has been formatted to NTFS which be read only on XO/2000 machines. The thing to do here is to load all your filed onto the Sony Then refomat to 32 bit - this makes a universal device but your Dell if I am right will not see the lappies stuff Come back with more detail
Jul 30, 2007 | FireLite (USBFLB80) Hard Drive
SmartDisk FireLite 80 GB Hard Drive Logo
32 people viewed this question
Top SmartDisk Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
 Ian Kayhan
Ian Kayhan
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
