Question about Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black
The coffee spout is pouring into the coffee pod collector
The coffee spout is now pouring into the coffee pod collector
container and no longer pouring into the express cup. Can someone help? Thanks
alix
I have the sameproblem, I suspect something is blocked but I don't know how to remove the spout????????? Please helP!!!!!
Posted on Feb 09, 2010
  • Norma
    Norma Dec 09, 2013
    have you found a solution?
The water does not flow through the spout. Can this be fixed or is it cactus?
YOU MAY FIND CACTUS IN THE GARDEN BUT YOU COFFEE MAKER NEEDS TO BE CLEANED OUT TRY CLEANING THE SPOUT FROM OUT SIDE WITH A LONG NIDDLE LIKE TO CLEAN THE CHANNEL PLUS RUN SOME WORM WATER TO MELT IT DOWN
Nov 14, 2015 | Nespresso U D50 Espresso Machine with...
My Nespresso U is sending the coffee out where the pod drops down not through the spout
YOU MUST CLEAN THE SPOUT TO MAKE WAY FOR THE WATER FLOWN PROPERLY TRY RUINING SOME WORM WATER FERST TO CLEAN UP AND MELT THE STUCK COFFEE
Oct 30, 2015 | Nespresso U C50 Espresso Machine...
Coffee dripping out of spouts instead of pouring.
You have not included the make and model of the coffee maker.
Oct 15, 2014 | Coffee Makers & Espresso Machines
How do I unblock the coffee spout of the jura 5
My Jura 5 was only pouring coffee from one spout, the other was blocked. I fixed it by removing the cover from the spout (see photo) it clips off with pressure applied to the sides on the dimpled part, then removing the brown reservoir inside after disconnecting the brown tube. Right enough, one side of the reservoir was full of coffee residue. I cleaned this with hot water and a tooth brush before re-assembling it all. The machine now pours perfectly from both spouts.
Oct 02, 2014 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Verismo 580 leaks clear water in spout behind pod spout
Be sure you put the silver lever (embossed with the word Verismo) down before pressing the coffee button. (The small cup illustrated on the top right.
Mar 02, 2014 | Starbucks Single Serve Brewer, Verismo 580
Carafe dribbles coffee no matter what you do. Pour fast, pour slow, dry the outside etc. Can't believe they can't make a pour spout that doesn't dribble. Any suggestions?
I often ask why we can put a man on the moon, but not make a coffee maker that doesn't dribble when I pour. I have the same trouble, and what I have found works for me is to be very careful that I am pouring with the spout dead center, and pouring fairly slowly. A little off to the side of the spout, and I'm cleaning the floor. But if I pour so the flow is right through the center, it works for me.
Good luck. And if you design the perfect carafe before I do, let me know. I'll buy one!
Dec 04, 2010 | Cuisinart DCC-450 Coffee Maker
Will not dispense the water into the cup when the button is pushed
I have had this issue. First, check to make sure water tank is filled and correctly in place? Try descaling it; a kit came with coffee maker. (It just removes hard water build up, it may be blocking your water flow.) If that is not the issue, pull the tray where the used pods are dropped -Is it wet? Like the coffee is pouring into this tray rather than in your cup? If so, I have removed round silver plastic piece from around coffee spout,(gentle -do not crack it) then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! If the POD tray is not wet, I would tell you not that most likely your machine is not clogged by grounds, so you may not want to take snout apart. I hope this helps.
May 02, 2010 | Nespresso Essenza C100 Espresso...
BUNN BT10B carafe leaks from spout down side while pouring
I emailed the company again and they are replacing the thermal carafe at no charge. Thanks!
Nov 15, 2008 | Bunn BT10B Coffee Maker
Nespresso C100B Essenza Single-Serve Automatic Espresso Machine, Black Logo
2,327 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
