Question about Craftsman 10" Table Saw
Adjusting The Alignment
I would like to know how to adjust the alignment on my 10" Radail Saw Model # 113-199-250
And also How could I get a Manual?
  • 843 Answers
You can view the manual (which includes the alignment instructions) at this web page. http://www.searspartsdirect.com/ Put in your model number, then when it finds it, there is a "View Manual" button on the right side of the page.
Please vote if you found this helpful
Posted on Feb 10, 2010
Can you advise me how to adjust the blade alignment on my Einhell table saw
I don't own one. Maybe you need to consult your manual for that . Look to this link . There are some good information on saw basics.
Apr 18, 2013 | Saws
How to fix wooden table top on arm saw 1875
If you want to turn that saw into a precision machine, get this book http://www.mrsawdust.com/ It is an incredibly informative book. I bought it after I picked up an old Dewalt radial arm saw. It was well worth the price. I never would have guessed how precise this tool could be, but it depends on knowing how to get the table flat and adjusting the saw alignment. Good luck, Al K
May 04, 2011 | Dewalt Saws
Rip fence to saw blade alignment
I dont believe there are pictures, but what you need to do is move the fence to the blade, there are 2 10MM bolts on the backside that you need to loosen and then you can move the fence to square with the blade. Snug them down and move the fence and recheck let me know if you have anymore problems
Jul 18, 2010 | Dewalt DW744S 10" Portable Table Saw with...
Blade is not parallel to the channel. How do I adjust it?
Instruction manual for your saw is here. See Page 21. You need to adjust your blade alignment to the miter slots. As mentioned in the manual, there are a couple bolts that hold the rear trunnion in place. Loosen them up, shift the motor a bit (not an easy task). Keep checking blade alignment until you've got it down.
There are after market trunnion alignment kits for table saws that make this a bit easier. Check out PALS (Precision Alignment & Locking System). For $20 or so, it makes the process MUCH MUCH easier.
If this post was useful, please vote. Thanks!
Mar 28, 2010 | Delta Machinery 10" Left Tilt Contractor'S...
I have a Craftsman 10" table saw model number: 137.248830. The saw doesn't make square cuts, it is more of a problem when using the miter. I have followed the alignment procedure so that the right...
I assume that your alignment procedure is about adjusting your miter gage. But you should first verify if the blade is parallel to the miter slot (the slot the miter gage slides in). This is adjustable underneath the saw, and sometimes comes crooked from the factory or comes loose later on. To check if the blade is parallel to the miter slot you can do this.....1. unplug the saw. 2. Raise the blade as far as it will go. 3. Clamp a piece of wood to your miter gage so that it just touches the blade as close to the front of the saw as possible. 4. Use a marker and mark that spot on the blade. 5. Now slide the miter toward the back of the saw, and rotate the blade by hand so that your piece of wood hits the same spot as where you checked in the front. You can see a large misalignment by eye. But you can get a little precise by using a piece of paper between the wood and the blade as a feeler gage. Or better yet, use a drop indicator instead of the piece of wood and you can measure the difference. If this isn't as close to parallel as you are able to measure it, you need to turn the saw over and find the bolts that attach the whole assembly under there to the table top. Once you have this in alignment, you should be able to set your miter to be square against any good square. If you don't have a high quality square, you can go to a tool store (Sears or whoever) with your miter gage in hand, and set it to be square against their most expensive square. If the square is square, and the blade is parallel to the slot and it still won't cut square you either have a bad blade or there is too much play in the saw's arbor. Try to wiggle the blade side-to-side - any wiggle at all is too much.
Jan 20, 2010 | Craftsman 10" Table Saw
I have a Craftsman 10 inch band saw. The blade keeps coming off. I can't find my manual. How do I adjust the alignment on it?
the blade tension shaft in the rear top of the saw should also have a tracking adjustment knob that tilts the top wheel. Open the top guard and spin the top wheel by hand and adjust the tracking knob until the blade atays on. Better unplug the saw until you get this done, then you can power the saw back up and fine tune the tracking while running until it is perfect. hope this helps you.
Oct 17, 2009 | Saws
I have my 2005 Odyssey brought to Europe.Now I need to do aligment.Even Honda services don't have alignent settings.Is anyone there who could help me???
Alignment: Specifications
Alignment
Wheel Alignment
Tire size:
VAN, LX, EX, EX-L models: P235/65R16 103T
EX-L Touring model: P235-710R460A 104T
Tire pressure:
Front (VAN, LX, EX, EX-L Touring models) ........................................................................................................... 230 kPa (2.3 kgf/cm2, 33 psi)
Front (EX-L model) .................................................................................................................................................. 240 kPa (2.4 kgf/cm2, 35 psi)
Rear ........................................................................................................................................................................... 240 kPa (2.4 kgf/cm2, 35 psi)
Caster angle ................................................................................................................................................................................................... 2° 32' ± 1°
Camber angle:
Front ........................................................................................................................................................................................................ 0° 00' ± 30'
(Maximum difference between the front right and left side: 0° 30')
Rear ............................................................................................................................................................................................................. -0° 30' ± 45'
The camber angle can be adjusted up to ±25' (center of tolerance) by replacing one damper pinch bolt with the adjusting bolt. The camber angle can
be adjusted up to 50' by replacing both damper pinch bolts with the adjusting bolts.
Front toe-in ............................................................................................................................................................................. 0 ± 2 mm (0 ± 1/16 inch)
Rear toe-in ......................................................................................................................................................................... 2 ± 2 mm (1/16 ± 1/16 inch)
Turning angle
Inward wheel 41° 56' ±2°
Outward wheel 34° 32' (Reference)
Toe - 0° +/- 2mm
Sep 22, 2009 | 2005 Honda Odyssey
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. andyc@bergeralllied.com
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
The chain on my Remington electric saw keeps jumping the sprocket. Solution? Thanks.
Depending to what model you have, the Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. Or your cahin is not tensioned properly. According to the manufacturer... "The adjusting block on the adjusting screw isn’t inserted into the adjusting hole on the guide bar. Reinstall and align the sprocket cover by first removing the sprocket cover from the saw. Turn tensioning screw on the sprocket cover counter-clockwise until it stops. Pull guide bar away from saw body to remove slack from chain. Insert sprocket cover tab into saw body tab slot and lower sprocket cover into guide bar bolt. Finger tighten guide bar nut onto guide bar bolt. Slowly push guide bar toward saw body until adjusting block on the adjusting screw drops into round adjusting hole on the guide bar. Securely tighten guide bar nut after properly tensioning saw chain." If these tips do not work, you may need a new chain. You can order an new chain on-line at www.masterparts.net. I hope this helps you!
Jul 01, 2009 | Remington Electric Chain Saw
Blade Alignment?
ok yep your blade is out of alignment with the fence. It is closer to the fence at the rear than the front. You need to make the modification or adjustment to your fence, if it allows that, and then worry about the miter slots later (which should be adjusted miter slot to blade, not miter slot to fence). You might be able to adjust the miter slot to blade by moving the actual table and then securing witht he table mount bolts. Check your manual for how to align the fence.
You do want to fix that though as it can be potentially dangerous and result in kickback of the workpiece which is a rather SCARY thing, and very dangerous.
Jun 01, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Craftsman 10" Table Saw Logo
107 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
