Question about Panasonic Workio DP-190 Multifunction Laser Printer
Getting error j43 on workio 190, but there is no paper jam
  • 100 Answers
Yep
it is common error for dp-180/190.
and the usual cause of that are worn out 2 bushings of heat roller
what you can do with that is to clean the fuser unit esp. the bushings of heat roller.
well off course the safest way is to replace the whole fusing unit.
that's it. :)
Posted on Mar 26, 2010
How to fix error code e04-01 after paper jam
Reset code in service mode F9/ram initialize/fuser reset/reset power
Aug 06, 2014 | Panasonic DP2000P Workio Spring located in...
I have a Panasonic Workio DP3030 showing error code J93 paper misfeed in ADF. I have followed the manual and there is no paper jammed but I can't get rid of the error message.
Generally a paper misfeed is not a paper jam. The rubber pickyp rollers probably need a clean but turning the printer off for 10 minutes and turning back on should eliminate the message.
Nov 03, 2013 | Panasonic Workio DP-3030 Printer
I have a Panasonic DP180 with an error message J43
more then likely you need to replace the fuser unit
May 21, 2010 | Panasonic PanaFax UF-8000 Laser Fax
I have a Panasonic DP180 with an error message J43 but I cannot find any 'misfed paper'. I have just changed the cartridge (only. Thank you and regards, Lynette
It seems that one of the switches under the toner cart is knocked off.Check and let me know, the update.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 09, 2010 | Panasonic Office Equipment & Supplies
Paper Jam J43
One of the switches under the toner cart is knocked off.
Aug 09, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Panasonic UF7100 J43 misfed paper error code
Did you pull out the toner cartridge and look?
Pull out the paper casstte, above that is a pull down access plate with a green handle.
Jan 08, 2009 | Office Equipment & Supplies
UF-8000 J43 Jam (Not There)
turn it around and have a look in the back panel that opens, open all other covers and check that any of the small black sensor levers are not stuck down they shoul all spring back
Apr 17, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Panasonic workio sp-190 machine says paper jam
This series of machine has frequent issues with the sensors in the paper path to detect timing and position. The sensors are actually optical but the utilize sensor"flags" to interrupt the sesnors light "beam". These sensor flags tend to pop out of position and/or break the springs. I have also seen the actual optical sensor fail.
Dec 24, 2007 | Panasonic Workio DP-2500E Copier
Panasonic Workio DP-190 Multifunction Laser Printer Logo
304 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
