Question about Acer Aspire One PC Notebook
Will not boot up, no audio and screen stays black. Has Windows XP.
  • 35 Answers
I would try a manual reset by removing battery and adapter.and hold down power button for 30 sec. then plug back in and insert battery and try to restart. If this doesn't work, please contact me again.
Posted on Feb 08, 2010
Windows XP Home Boots midway and screen go black.
Follow the tips below to fix the problem:
  • Scan PC for Viruses
  • Clean Registry
  • Run Last Known Good Configuration
  • Repair Windows
Mostly professionals recommend Intel Partner Software, RegInOut System Utilities to fix the Windows boots to black screen problem.
Dec 27, 2011 | Microsoft Windows XP Home Edition
Whats the problem when computer boots, the loading progress bar og windows XP is displayed, but as soon as the computer goes into Windows XP, the screen turns black and stays black?
you coform the problem comes only when printer connected.
detach the printer cable from system and boot the system.
the problem still persist then reload the Win XP
re install the printer driver.
the problem will be solved
alexander
Apr 15, 2011 | HP LaserJet 1320 Printer
Black Screen on Dell Dimension 3100 on boot up. Running Windows XP Home Edition. This happen before you get to the Windows login screen.
If you have a black screen it means the system cannot boot into your master boot record, you should reinstall the system using a bootable Windows XP CD, and perform a repair,( not the Repair Console).
When youre in the Windows XP Wizard screen, press enter , accept the license agreement, and then it will check for existing windows xp partitions, press R to repair the existing Windows XP installation, and wait til it gets your system restored.
Jan 10, 2010 | Computers & Internet
My computer only boots successfully after a forced shutdown.
Is it possible that you have installed winxp twice? You say that you installed XP Pro sp3 was that an upgrade from xp home? if so then you will need to uninstall one or both versions of XP then install only one.. Make sure you backup any important files first though
May 22, 2009 | Microsoft Windows XP Professional SP3 Full...
The screen turns black and stays like that
Normally it's because the resolution is set too high for the monitor. This has happened to me when I switch a computer from a flat screen to a old "biggy-size" monitor.
try rebooting the computer and BEFORE you see the windows splash screen, start pushing the F8 key...this should bring up a menu...select VGA Mode...it won't be pretty, but once you're in..right click on the desktop and change the solution (try 800x600). restart the machine...that should work.
-SuperDale
May 05, 2009 | Apple Computers & Internet
Black screen after fresh install xpmc 2005
Are you able to go windows safe mode if yes ... Start > Run > Msconfig > Ok
in the general tab you have option to seleect Normal Start up > Click on apply and ok and restart yiur computer that should work
Apr 09, 2009 | Microsoft Windows XP Media Center Edition...
Toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
Your description of the symptom shows that your operating system installation has been corrupted. Fastest and easiest way to resolve the Issue using the "Recovery and application disk" (it comes with laptop) to perform full system recovery. I would like to remind you full system recovery will erase everything saved on Hard drive. You can check possible option on http://support.toshiba.com
If you dont have recovery and application disk you get one. You can call Toshiba @ 1-800-457-7777
Please post if you need further assitance
Good Luck
Jan 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
1. Go to this website and download Ultimate Boot CD
2. Now download this tool to burn this Image
This is the program you should have downloaded.
Now that you have the program where it says file location look for the location you downloaded your file. Usually its C:\Downloads but it could be in a different location. Once you've located the file burn it to a CD or DVD of your choice.
4. Once you boot this cd you need to look for Partition Manager click on it. Click on HDD and then look for FDISK.
Make sure that you have an active partition which should say C: Active
Dec 03, 2007 | IBM ThinkPad T20 2647 Notebook
Black screen.
To get into the Windows XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to " Last Known Good Configuration (your most recent settings that worked)" and press your Enter key. This should load windows and operate normally. If it doesn't then reboot & press F8 again then select "safe mode". In safe mode, Windows XP starts a minimal set of drivers that the operating system needs to function. Support for devices such as audio devices and most USB devices are disabled to reduce the variables that you need to account for when diagnosing the cause of startup problems, Stop messages, or system instability. If recently installed hardware or software prevents you from starting Windows XP in normal mode, you can use safe mode to uninstall software, or to remove or roll back device drivers. Let us know how you get on - Good Luck!
Aug 11, 2007 | Dell Latitude C610 Notebook
Acer Aspire One  PC Notebook Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
