Question about Canon Image Runner 3320I Copier
IR 2200 Fax board speaker
Where do I install speaker
  • 86 Answers
As you look at the copier on the left hand side there is a panel that is inbetween the print engine and the scanner this panel has small holes in
You fit the speaker behind that panel there is the 2 pin connector fit the speaker and connect it
Any problems please get back to me
Thank you
Posted on Feb 22, 2008
Error code E002
I googled: canon imagerunner 2022 copier error code e002
This appears to be the best and most informative: http://www.fortwayneprinterrepair.com/wordpress/2014/08/12/canon-ir-2200-2800-reset-fuser-error/
If not, try some of the others from the above search.
May 07, 2015 | Canon Image Runner 2022 Copier
How i fixes error code e000002 i change new fuesr unite but the error code is not remove pleas help how to solve?
http://www.copytechnet.com/forums/canon/5317-canon-ir-2200-error-code-e000002-0000-a.html
Aug 10, 2014 | Canon Ir 2525 Copier new
Problem with printing on canon ir 2200
go to run prompt on client end and typ \\ip add of main pc where ur printer actually connected nd then u will get shared printer on display, u will get shared icon of ur network printer right click there nd connect it .... if it doesnt show any problem to connect it will work nicely ...........
Apr 16, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Ir 2200 hard drive crash
That's probably because you're not a tech. The hard drive is not a user replaceable part. Get a tech to replace the hdd, format and install system software using sst.
May 03, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Canon ir-2200 error E602-0002
E602 Hard disk failure.
Your hard drive probably has a problem, check connections, unplug everything from the board let sit for a few minutes then replug everything.
Sep 30, 2008 | Canon imageRUNNER 2200
Canon ir 2200 copier. error code E000003-0000
thermistor, thermofuse or heat lamp bad, change
Sep 09, 2008 | Canon Office Equipment & Supplies
Canon imagerunner 2200
yes you can do your self.. when u recive the fax boart the company giving instalation manuval along that box. if u follow that instrction u will do that.. all the best..
Aug 16, 2008 | Canon Image Runner 3320I Copier
Hello nick. The speaker goes behind the cosmetic support cover located between your left knee and your waist (if you are 5' 7' ). There are 2 screws.One upper left,one middle right. I am viewing the sevice manual and have not done this personally. It appears the wring is pulled for you already. Hope his helps.
Feb 22, 2008 | Canon (6981A002AA) for imagerunner 2200,...
96 people viewed this question
old marine
old marine
