Question about Nintendo Wii Console
I bought a Nintendo Wii off of a guy and I didn't realize when I did that it came with Hi-Def RCAs. My TV only has a standard RCA hookup. I was told that I could still use the Hi-Def RCAs but what colors go where? Red, Blue, Green (Hi-Def) goes where on the Red, Yellow, White (standard) hookup? Thanks for helping!
    Scholar:
  • 130 Answers
Those are not High Def RCAs.
The cables you received are called "component" when the picture is broken down to its component colors, red, green, and blue.
When compared to "composite" cables (RCA), the yellow is all the components in one, which is the video cable. The other red and white are audio.
Your component should be RGB, Red & White (audios)
What you need to do is buy a composite cable for the Wii, which shouldn't cost that much--usually under $10 bucks. Save the component cables for when you get a new TV since those are the more expensive of the two!
Posted on Feb 08, 2010
How do i hookup a wii to the tv set so i can receive netflix over the the television
Use the available RCA connector that came with the system. Yellow, Red, White. Just like you would hook it up if you were going to play a game.
Jun 26, 2014 | Nintendo Wii Console
Plugged in my wii after several months of not using it, it work excellent when I unhooked it. Now the picture has no color and very faint
I would first check your cables. It seems as though the RCA cable could have a problem, OR if your using a standard def set up (Yellow=Video, Red/White=Audio) make sure the TV input is not set on component. Component input will be looking for an RGB input method. Try using another input, make sure the wires are plugged in the right location, and the input is set correctly. Hope this helps :)
Nov 26, 2013 | Nintendo Wii Console
N64 colors do not work when hooked up to Vizio TV.
You probably have the RCAs in the component video hookups. Its easy to confuse them as they are similar ports. They are usually red, blue, and green. Look for the yellow, white, and red hookups. Those are for RCA connections as they don't work in the component hookups for HD video. i.e. blue-ray, PS3 That will cause the video to look grey and grainy.
Sep 14, 2012 | Nintendo 64 Console
I bought 19in flat screen sylvania TV I wii to it and get no picture
What king of hookups do you have for the wii? Component? a/v? If they are red white and yellow and are hooked up to tv, some tvs have multiple a/v hookups. Be sure you're on the right channel
Jan 03, 2011 | Nintendo Wii Console
I have downloaded a handful of games from the Nintendo Wii Shop. When I go to play one of these games, the screen continues to skip and doesn't work. I have absolutely no issues through when I insert a...
HI on my wii I noticed the same problems when using high def a/v cables and I had to hook the regular a/v cables up. Are you using regular standard a/v cables?
Nov 24, 2010 | Nintendo Wii Console
Screen set up will not change
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
raterakash12
Jan 07, 2010 | Nintendo Wii Console
When I turn on my wii all I get is a black screen. The Wii is on but the main menu wont come up and I cant see anything.
Make sure the your RCA (Red/Yellow/White) cables are connected into standard input RCA slots on your TV. If they are connected to the HD RCA slots or the the standard output slots on your TV this problem may occur.
Dec 17, 2009 | Nintendo Wii Console
Problem with Wii
i think you haven't plugged in the correct RCA cables. you have plug in the yellow, white, and red. or you might not have the RCAs plugged in
Jan 31, 2009 | Nintendo Wii Console
Wont turn on green light comes on then shuts right off
Wii is compatible with all projection TV, try lowering down resolution settings on Nintendo and check PAL/NTFS settings.
Jan 09, 2009 | Proscan PS35660 TV
Hook up
hi, im using a HDTV with my wii, but im just using the standard cables ie, wii - skart connection , one to wii sensor, and one to mains plug from wii,
and works fine..
All the best
john
Jan 02, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
107 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
