Question about Dell OptiPlex 330 Desktop Desktop Computer
Have just had Windows re-installed on my computer. Now some of the keys don't do what I expect them to do; in particular, the @ and " are transposed. Help please.
    President:
  • 2,678 Answers
Select correct regional and language settings in control panel.
Posted on Feb 08, 2010
How do I navigate Menu for colors, brightness, etc.?
Howard
Hello
Some monitors you can configure, in options video, inside windows. and configure , contrast, or brighness too.
if you can go into menu in your particular monitor, then you can in advanve, change those settings. and save them.
good luck!
Nov 14, 2015 | Gateway FPD1975W 19in Flat Panel TFT-LCD...
The use of the Transposer control. I am very much a beginner in music in spite of my advanced years, and I have been puzzling over how to use this control. Would I be correct that all I need do is to...
A SIMPLE way of looking at the transposer is that it shifts EVERY key on the keyboard left (+) or right (-) by the number of the transpose. ALL keys, black and white are counted. As far as counting sharps and flats I would NOT depend on that. The transpose would for instance allow you to play a song you knew in "C" and have the sounds moved to a different key. For instance, a transpose of +2 would move EVERY C to "sounding" D, C# to D#, D# to F, E to F#, F to G, F# to G#, G to A, G# to A#, A to B, A# to C, and finally B would sound C# pitch. Given a key like G for a song that has one sharp (F#) to play this by keying it in the key of "C" you would use a transpose of +6 or minus 6. The number of key positions (including black) between the key you want to play in and the key the song is in. For a song in D that is played in C you would use either a +2 transpose or a -10 depending on whether you wanted the higher or lower octave to sound. Looking at it this way I do NOT believe the method you proposed would work... Look at it the way I described and you won't go wrong.
Jul 26, 2011 | Yamaha Music
HI, I have a Roland Juno GI, (5 months old), have not programmed anything into it or changed any settings. However, when I started it today it was flat by 50 cents. I was sure of this by checking a D or G...
It sounds like it is transposed. Look for the transpose function in your user manual. It shifts the keys by half notes either up or down. I would be surprised that factory reset would not clear the transpose setting. First, realize that these keyboards are controlled by a crystal oscillator and they just don't drift enough to shift even one cent worth.
IF the unit is NOT transposed, then the other problem is LIKELY with the pitch bend wheel. Try the action of the wheel and make sure it responds by moving up and down about 50 cents. If it doesn't go both ways, it is possible the mechanism has slipped or been damaged.
Jul 19, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
Were to find the serial number in yuri's revenge?
Don't look for serial numbers for RA2 or any other games. But, search for its KEY GENERATOR. So that you'll have an unlimited serials for a particular game. Also, search for CRACKS, so that you can skip the CONNECT TO INTERNET part of installing the game.
Rock and Roll!
Jun 12, 2011 | West Wood Studios Command and Conquer Red...
How to install a fresh OS in my dell optiplex110?
You would need the restore discs to preform this.
May 03, 2011 | Computers & Internet
I have Casio Ctk-496 and I have MIDI-USB wire. It all works, but Transpose button doesn't transpose and casio chord doesn't work with my computer. And all is still working even if I pull out IN wire from...
Casio Chord is internal to the keyboard and doesn't come out on MIDI. Transpose is similar and while the button may send a MIDI transpose type signal out, the notes will not transpose in your computer...
Mar 30, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
How to install windows 7 operating system
To Install the Windows 7 Operating System (Win 7 OS):
Instructions for a "Clean/New Windows 7 Installation:
AFTER BACKING ALL YOUR DATA THAT YOU DON"T WANT TO LOSE, Do the Following :
1) Insert your Genuine Windows 7 System Disc (Retail or OEM System Installation Disc).
2) Close down all programs and restart your computer.
3) As soon as the computer restarts, you should see a prompt that says something like this: "Press any key to boot from cd/dvd"
....So press any key!... This will boot to the installation disc and prepare for installation or repair (we are going to be installing windows, so ignore the repair options you see on the screen).
*If you don't press a key in time, you will see that the computer will attempt to boot from the hard disc drive instead... if that happens, restart the computer and press a key when prompted.
4) Depending on your particular Windows Version, you will see a prompt that says something about "Do you accept the license terms?" Click "Yes" or "I accept", etc.. and continue on...
5) Choos Custom or Advanced Settings (the other option is for an upgrade..)
6)Select the desired hard disc drive, (HDD aka Hard Drive), Select "Drive Options", and follow the onscreen instructions "Delete the partitions" (Do not Leave another windows installation on the same hard disc drive, unless you are experienced and know how to "dual-boot" properly!) Delete the Partitions.
7) Now choose to install windows (be sure to select the newly deleted empty (unformatted) partition. Windows 7 will automatically format the drive for you and will begin to install windows 7. Follow the onscreen instructions and within a half an hour or less (depending on your hardware) you will be finished, just be sure not to leave the computer unattended while performing a windows installation, since it requires your input quite often to proceed.
That's pretty much all there is to it!.. if you have any more trouble...
Google it or Bing it.... Search Engines are awesome!.... Enjoy!
*NOTE- If your windows 7 disc is a "Upgrade" disc, then you must perform an upgrade while running your previous/older windows version, since Windos Upgrade Discs aren't bootable, they simply patch the older version, replace system files, etc... to transform the previous windows installation into the target/newer version. If you want to perform a clean install, be sure you own a Windows 7 Installation / System Startup Disc.
Jul 06, 2010 | Intel Motherboard
@ and '' keys transposed
The keyboard may be set for a region other than yours (USA?).
[Start]
[Control Panel]
[Regional and Language]
[Regional Options] tab
Click on the down-arrow on the drop-down menu
and select your region ["English (United States)"] or whatever.
[OK]
You may want to review the settings in the [Languages] tab.
[OK]
Oct 08, 2009 | Computers & Internet
Transpose feature on the Roland RD-600 digital piano
If you want to play in C and carry the sound of Bb,
1. From C, count down two half-steps to Bb
2. Press and hold the Transpose button and press the key on the keyboard that displays through the window, "-2"
3. To turn off the transpose feature, just press the Transpose button again.
Feb 23, 2009 | Roland Vs-2000CD Digital Studio...
Two keyboard keys seem to have been transposed
Yes when going through the setting up procedure for your new computer you should have installed the British keyboard instead of the US one.
Doing the above will correct your problem.
Nov 09, 2008 | Computers & Internet
Dell OptiPlex 330 Desktop Desktop Computer  Logo
24 people viewed this question
Alun Cox
