Question about Kenmore Washing Machines
We have a Kenmore HE4 Gas Dryer, model # 110.9586, purchased in 2005. Recently it has stopped producing enough heat to dry a load. It takes about 3 hours on timed dry setting high to even come close to drying a normal sized load. We have cleaned the exhaust vent, scrubbed the dryer screen and vaccumed inside the cavity of the screen and back. It's gas supply valve is open and working fine. I can even hear what I think is the gas ignition after a small amount of time when it's in start-up. I see steam outside of the house where it is vented, but it doesn't seem to be the normal amount.
  • kate9 Feb 08, 2010
    The 110V wall receptical is providing the correct voltage. Would the drum rotate if the motor was not rotating properly? FYI - The drum is rotating as normal. Timer does count down correctly for whatever setting is used. Can you tell me where the pressure switch is located, and if you have a part number for this specific model? Thx.
  • kate9 Feb 16, 2010
    It was not the thermal fuse, and the location for finding that fuse was incorrect for this model.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check the lid switch is fine. Check the connector voltage which should be 110V. Also check that nothing is jamming the motor to hinder it to rotate. If still the issue persists, then it means that the pressure switch or timer has gone bad. Replace whichever is required.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 08, 2010
  • Rylee Smith
    Rylee Smith Feb 08, 2010
    Hi
    Thanks for your reply. From what you have described the issue seems to be with the Thermal fuse which is mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
My electric dryer takes a long time--3 hours or more to dry a load of wet towels
The heating element may have failed. Also, the vent may be clogged.
Aug 15, 2016 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Gas Dryer Shuts off prematurely in the Auto Dry cycle and the Timed dry cycle
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Jul 19, 2014 | Kenmore Dryers
Kenmore 100.85081400 no heat
check the thermal fuse on the blower housing if its open some units wont heat,also check the heating element if heated electrically,or the ignitor on gas fired units,by the number you provided i believe you meant its a 110.85081400 instead of the 100.85081400 (and is electrically heated) you provided which is produced by whirlpool for sears (kenmore) also there is a control board located inside behind the control panel that may be a culprit,but check the first two things i suggested at the top
Jul 23, 2012 | Kenmore Elite HE4 Electric Dryer
The air drying the clothes is cold, not hot. We have a Kenmore Elite Electric Dryer, Model 110 63952100
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore elite he4 dryer is not heating up to dry the clothes
heatman101
Oct 10, 2010 | Kenmore Elite HE4 Electric Dryer
HAVE A MODEL KENMORE ELITE He4 ELECTRIC DRYER. IT
Check the burner tube and clean it out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer will turnover, produce heat, but will not dry clothes and after 70 min, lots of moisture in dryer
Sounds like the dryer is not venting. Check to see if the vent tube is kinked or the end is covered.
Sep 23, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore gas front load dryer.Very little heat, takes 3x to dry
Check your heating elements. check the outside exhaust door is it open.
Feb 20, 2009 | Kenmore 93142 Gas Dryer
Dryer not heating
what is the model #the heater is not in the back of the he4.
Oct 21, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
23 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
