Question about Hoover F7431-900 SteamVac Vacuum
Steamvac drips when tilt to pull back
The gray tray that clean water and soap are dispensed into (through) seems to hold water because every time I tint the handle to pull back the machine, it pours or drips water onto the floor. The water/soap holder is not leaking.
My one year old, lightly used machine was doing the same thing. The original tanks have a design flaw, develop hairline cracks. New tanks have been redesigned, but cost fifty dollars.
Posted on Mar 14, 2008
    President:
  • 1,673 Answers
May have a problem with the seal at the bottom of the tank, the valve and seal sometimes go back and need to be replaced(#43513026).
Posted on Mar 01, 2008
Will spray water, but not solution
Hi there! The clean water tank has two spring loaded valves that releases the contents. Fill the clean water tank with water on both sides. Hold the cleaner up and push the valves in on both water and solution side. Both valves should push in and contents should drip out. If not, the clean water tank will need replacing. To order a replacement tank follow the link. Search Results The type of solution you are using can also prevent the solution from dispensing, be sure you are only using the recommended cleaning solution for this cleaner. If the clean water tank valves seem to be working fine, there may be an issue with the pump assembly that delivers the solution. We would recommend taking the cleaner in to an authorized repair center for service. To locate the nearest service center to you follow this link > Service Center Locator Hope this helps!
May 31, 2014 | Hoover F7452-900 All-Terrain SteamVac
No water/cleaning solution comes out on wash cycle
With this model, the soap dispensed is controlled by electric solenoids. these can be tricky to troubleshoot. I would take it to your nearest dealer. these solenoids fail, and cause a variety of symptoms.
Oct 08, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Water does not dispense on wash cycle
this would be the soap/ water valve. it is stuck closed or isn't opened.( no cure for an non-opened valve, just replace.)
Jul 16, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Part broken to dispense cleaning solution.
Most of the time you can only get the tank. part number 42242134
Jun 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover carpet steam clear
Is this a V2? The F5914-900 just has a solution tank. The V2 has a small soap tan attached to he water tank. If you have a V2, the seal or plunger at the bottom may be bad and can be replaced. The reservior asm. that the tank sits on may be bad. You may have a problem with the tank in which case it will have to be replaced.
May 08, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Model F7441980 Hoover Dual Action Spin Scrub Wide Path
You will have to replace the tank, and it will come with the soap dispenser attached.
Mar 30, 2008 | Hoover SteamVac F5914-900 SpinScrub...
HOOVER STEAM CLEANER PROBLEM
The soap dispenser is supposed to be attched to the water tank. That grey piece, if it is round with 2 small ears on it is the metering plate, it controls the flow of water. It sits on the table that the tank sits on, insert it into the hole and turn to lock it in place.
Jan 14, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover steam vac v2
Either you need a new tank, or there is a problem with the platform that the tank sits on. The tank has to sit correctly or it won't work.
Oct 21, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Cleaning Solution leaks out around bottom
Most likely the opening under the seal has cracked or is starting to break away. You will have to replace the water bucket, the soap dispenser come with it, not separately.
Oct 20, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
108 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
