Question about Toshiba Satellite A135-S2276 Notebook
RE: bios password reset
1)Remove Laptop Battery2)Take off Memory Cover(underneath - square cover, Sits in middle of laptop 1 retaining screw3)Using two thumbs spread spring clips to outside and pull out RAM memory.4)Remove clear vinyl label opposite RAM memory slots in upper left corner( laptop battery slot is on right, DVD drive is facing away from you)5)Using a magnifying glass (unless you have perfect vision)in the upper left corner you will see JOPEN1 with a white silkscreen square next to it . Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4" post connecting the motherboard to the laptop case(this is you ground, it is located above what looks like a silkscreen outline of a chip)hold for 25 -30 seconds.6) Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Now hit F10 key ,yes to save and your done! --- i tried this but when i turned it on there no display in my lcd help!
  • eiyee Feb 22, 2008
    how can i see the CMOS battery? model satellite A135-S2276
Whahahahhaha,,,,,,,,,,,,,,,
heres a good solution on the net
by Elf Qrin (http://www.ElfQrin.com)
Posted on Aug 06, 2008
    Genius:
  • 1,019 Answers
Sounds a bit dodgy to me.
Where did you get this information From. I hope you removed the battery before you did any of this stuff.
If you did,nt you could have damaged-RAM-CPU-Motherboard.
heres your only suggestion. if you have an external monitor output ( usually on The Back ) behind a pull down flap or cover.
Plug a standard pc monitor into this, boot up the laptop, so that you can at least view whats going on in there.
Are you getting any Beep Codes ?
Mike @ Compurepair.
Posted on Feb 22, 2008
  • 28 Answers
You have to remove the CMOS battery then put it back in to reset the password. The CMOS battery is on the motherboard itself, so you will need to strip down the computer to the motherboard and do it. The battery looks like a little watch battery. There are a few online tutorials you can find on google to take apart your computer.
  • Tim Kelso
    Tim Kelso Feb 22, 2008
    once you have everything taken apart and the motherboard is out, you will see the little round CMOS battery. It may be covered up by a piece of material, so look very closely.
How to reset password,bios
check the video as well
https://www.youtube.com/watch?v=Eo1gg1EZV-o
Apr 03, 2015 | Toshiba Satellite A135-S2276 Notebook
Bio passwod removal hp laptop
How to Reset an HP Laptop BIOS Password
Reset the password on any HP laptop.
Reset the BIOS password on an HP laptop computer when it has been forgotten or when preparing the laptop for sale to a new owner. Learn how to erase an unknown BIOS password by physically disconnecting the internal batteries. Avoid spending hundreds of dollars at a service center to make changes that can often be performed at home by anyone with the ability to take an HP laptop apart and put it back together again.
Items you will need
  • Small screwdriver set
  • Flashlight
Step 1
Power down the computer if necessary by holding the power button down for six seconds until the power shuts off.
Step 2
Disconnect the power cord from the HP laptop computer. Remove the battery by flipping the computer over onto its cover and releasing the battery clips as indicated by the illustrations on the bottom of the laptop or in the owner's manual. Lift the edge of the battery nearest the clips up first, then pull the battery out of the laptop.
Step 3
Remove the screws that hold the hard drive cover in place and remove the cover. Take the hard drive out of the laptop by removing the two retaining screws and pulling the drive gently away from the connector, then lifting the hard drive bracket or tray out of the computer.
Step 4
Remove the screws that hold the memory compartment cover in place, then remove the cover. Remove the memory modules from the sockets by spreading the metal retaining clips gently apart and allowing the module to spring upward. Pull the memory straight out of the socket at the angle it rests at when sprung from the retaining clips.
Step 5
Remove the Real Time Clock (RTC) coin cell battery from the memory compartment by pressing the retaining clip and pulling the coin cell battery out of the socket.
Step 6
Allow the computer to sit without the battery for an hour, then reinstall the memory and hard drive, but leave the coin cell battery and the main battery out of the system. Connect the AC power adapter to the system and power it on to clear the BIOS password.
Step 7
Power the system back down and remove the power cord to reinstall the coin cell battery and main battery.
hope this helps
John
Nov 17, 2012 | Microsoft Windows 7 Home Premium 64BIT...
Toshiba satellite pro sp2100 -> Mod No: ps210E
TOSHIBA
Remove Laptop Battery Remove Memory Cover Spread spring clips to outside and pull out RAM memory Remove clear vinyl label opposite RAM memory slots In the upper left corner you will see JOPEN1 with a white silkscreen square Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
May 15, 2011 | Toshiba Computers & Internet
Cant find cmos battery on toshiba satelite l300 motherboard, need to reset hdd password
You cannot reset a HDD password (if its a bitlocker one) and you have lost your encryption key reset file and forgot password.
if you mean the BIOS/Power on password then try this
May 10, 2011 | Toshiba Satellite Pro L300 Notebook
I have dell vostro 1500 laptop i forget my bios password my service tag is 39X94F1=595b
Follow the steps below to reset/remove the bios password.
  1. Turn off your computer.
  2. Remove the battery and disconnect the power cord.
  3. Turn over the laptop and unscrew the small cover which is retained by only one screw.jbertrand_ba_1.jpg
  4. Once the cover is removed, you will find the memory module.
Now under the memory module, you will find a blue plastic sleeve connected to the mainboard with a single wire. Disconnect the wire and wait about 30 seconds - 1 minute before reconnecting it. Replace memory module and put back the cover and screw it.
Replace the battery and reconnect the power cord.
Turn on the laptop and you will not be prompted for a password.
If you would like to put another BIOS password, restart the computer and enter the BIOS setup and there you will be able to define a new password.
May 10, 2011 | Dell Vostro 1500 Notebook
I need to reset the bios password on my daughters laptop
ReSetting Bios Password on Toshiba Satellite A135-S2386
5)Using a magnifying glass (unless you have perfect vision)in the upper left corner you will see JOPEN1 with a white silkscreen square next to it . Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4" post connecting the motherboard to the laptop case(this is your ground, it is located above what looks like a silkscreen outline of a chip)hold for 25 -30 seconds.
Note: if your having trouble your most likely grounding the ground(that blob of solder about 1/8"dia on both ends of the "silkscreen chip outline"
Sep 23, 2010 | Toshiba Satellite A135-S2386 Notebook...
I am a tech trying to reset the password on a Toshiba 135-s2326
ends of the "silkscreen chip outline" This is about as simple as i can break it down
There is no guaranty this will work though.
Jan 05, 2010 | Office Equipment & Supplies
Reset bios password don't remember the password to get into bios
The best solution is to remember your password. If ther is no way you can remember the try these steps..
Regards,
Jeep Brainy
Aug 10, 2009 | Toshiba Satellite A135-S2276 Notebook
I have a tosiba sattlite lap top that i frogot the pass word on
http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/208408-solved-how-do-reset-bios-password-toshiba-satellite-a135-s2276.html
Re: How Do Reset Bios Password In Toshiba Satellite A135-s2276 ?
tell please ! i ready for do this now ...
Dec 27, 2008 | Toshiba Satellite A135-S2386 Notebook
Cmos password reset
ok
plz goto my profile and see my all solutions i have given many times answer on this topic.
If you dun find tell me i will copy again for you.
And also tell me about your feed back.
Thanks
iqbal
Mar 15, 2008 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
117 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
