Question about Maytag PGR5710 Performa Gas Kitchen Range
F1 display on gas range, cannot turn oven on. Is it worth repairing or do I need a new range?
  • Maytag Master
  • 3,249 Answers
The f1 code is defective clock or pad google your stove there is a list of codes
Posted on Feb 08, 2010
Oven is on and won't turn off. Fuction code "F1" is displayed. Have to shut power at circuit breaker???
If oven is electronic /gas keep circuit breaker off.... check and see if it is still under warranty and/or if it is a call center you can call 4 repair....also... if gas you might want to turn off gas valve in the back of oven until oven is repaired.......F1 is a error code!
May 15, 2016 | Kenmore Kitchen Ranges
My Kenmore Elite Gas Range is reading F1 on the display....the gas burners work on stove but the oven wont work....any ideas??
The F1 error code is a failure of the electronic oven control. This could be caused by a stuck keypad or an internal malfunction of the control. You will need to disconnect power and wait at least 30 seconds, reapply power and if condition still exist you will need to replace the electronic oven control.
You will also need to check if the oven is overheating. If the control has sensed a runaway oven temperature it will display an F1 error code. This could indicate a failure of the oven temperature sensor.
Hope helps.
Jul 18, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Electric Range.-oven stopped working. Error Code F1 show on electronic display
Hello there:
Here is the 2 most common f1 codes for this oven and what the problem is and what repair procedures that should be taken
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC)
Dec 13, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Magic chef gas oven will not turn on
F1 means, defective touch pad or control.
Jan 09, 2009 | Magic Chef CGR3725 Gas Kitchen Range
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
DISPLAY ERROR F1-8
F1-8 commonly means shorted membrane. Unplug or shut off the circuit breakers for 15 minutes, plug back in/turn back on, if problem persists replace membrane, if they are integrated parts replace control board (some come with membrane on parts vary)
Always shut off power before any repair attempts electrically
May 01, 2008 | Jenn-Air JGS8850ADS Gas Kitchen Range
F1 and F2
depends on the brand, most of the time its an erc (electronic range control) this can be replaced. find a appliance store near you, give them the model and ask for the price and availability of an erc. If satisfied call a tech. If a tech installs it you have a warranty... get the picture?
Feb 08, 2008 | Kitchen Ranges
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Maytag PGR5710 Performa Gas Kitchen Range Logo
157 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
