Question about Maxtor OneTouch 4 Plus 750GB External USB 2.0/FireWire 400 Hard Drive
My maxtor Storage Unit dropped and stop working.
My Maxtor One Touch 4 (1 Terrabite Memory) Data Storage Unit dropped on the side and stop working. It has a hum and the function light stays on but not responding.
Is there a recomended Repair Shop in or close to N Miami Beach, Florida 33162 I could take it to be repaired?
Thank you.
Alden
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
Maxtor personal storage 3200 stopped being recognised, clicking sound coming from box
The clicking sound from a hard drive is known as "The click of death". This drive is faulty and if you need data off this hard drive then there are companies that can recover data off a faulty hard drive BUT it will cost you an arm and a leg for their services.
Jan 31, 2013 | Maxtor Personal Storage 3200 (U01E200) 200...
My Maxtor Model one touch ll 300 gigabyte storage unit quit working and I can't recover my data. What will it take to recover my data, and what will it cost.
more than likely its a power issue. located inside the case cover is an actual hard drive that can be directly hooked to your computer internally. its all plug and play. if you have any questions , feel free to ask. if this info was helpful please leave a testimonial on my fixya page.
Dec 20, 2010 | Maxtor OneTouch II external hard drive...
My 10 pin data connector broke off inside the case--can I take this somewhere for assistance with repair and data recovery off of my device? it is a maxtor one touch III mini
The answer is Yes.
You can recover lost data from USB with data recovery program.
CardData Recovery can recover data from all camera flash memory cards includingCompact Flash Card (CF), Smart Media Card, Secure Digital Card (SD),Multi-Media Card (MMC), XD Picture Card (XD), Micro Drive, Sony Memory Stick(Duo, Pro), as well as removable storage including Zip disk, USB drives andHard drives. Recovery of files is also possible even when drive has beenformatted.
Oct 25, 2010 | Maxtor OneTouch III Mini Edition 120GB...
Storage disc stop working
It could be a situation where only the "table-of-contents", which describes all the files on the disk, has become scrambled. So, look online for "file recovery" utilities -- programs that will read through all the blocks of data on the disk, and try to "stitch" together all the files, without using the "damaged" file-directory.
May 31, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
Need to locate a working identical Maxtor 3200 200GB
Well this is not how I like to answer questions on this forum, but here is a place to start looking for your drive. I hope this helps, there are some listed.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=+Maxtor+3200&_sacat=See-All-Categories
Sep 15, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200
Try connecting the Maxtor to another computer and if it functions normally, then backup your data. Then try formating the Maxtor on your computer.
Sep 08, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 320gb External hard Drive Question
You can remove and disconnect the drive with out losing data. Since it is a usb drive its always best stop the device before removing. You do this by clicking on the icon in the task bar . It has a green arrow above it. As for the safety drill have not use it but should be able to get instruction once you install it ( look at the help files ) Hope this helps
Jan 25, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
500gb hard disk - ticking sound - is data gone?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Oct 20, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Hard drive tries to work
I had this problem also. It was either dropped or something fell on it. You have to get it repaired or a new one. If you have VERY important information that cannot be replaced, consider a data recovery service from your local stores.
Good luck with your Drive.
Aug 14, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor One Touch 80 Gig Drive
Go into the device manager and clear the USB ports.
Apr 19, 2017 | Maxtor One Touch (RBAY080B0USR) Hard Drive
Maxtor OneTouch 4 Plus 750GB External USB 2.0/FireWire 400 Hard Drive Logo
351 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
