Question about Broksonic Televison & Video
I am not on cable. The Broksonice tv I have does not have a remote. There is no menu button on the tv. I have a Phillips HD indoor antenna with black box and remote. It does not respond to the Broksonic tv; only snow on the screen. How can I get local Louisville channels without subscribing to cable?
Just through it away and get a new one
Posted on Feb 08, 2010
The model # is: L42FHD37. I need to know how to set up an amplified indoor HDTV antenna. RCA multi directional serial # ANT1450BFW.
Attach the antenna to the antenna/TV input on the back of the TV. If you have a flat twin lead wire on your antenna, you'll need a co-ax converter. (Best buy, etc.) Power on the TV (and the amplified antenna) and use the Input button on the remote to select the TV input. Next use the menu button to select channels and then engage the auto-search option to memorize all of the available channels in your area.
Feb 29, 2016 | RCA Lg 42ls5700 42" 1080p Flat Panel...
Phillips Magnavox TV-is this HD?
then you will need a converter box,there is no analog signal anymore,it was changed to digital,your tv is not hd if you dont even get one channel,you also need a hd antenna,
May 15, 2015 | RCA Televison & Video
I got a rca home theater older model TV....how do I program it to receive digital channels using and indoor rca HD antenna
Let's assume this is a digital TV, not one of the old analog home theaters. First hook up the antenna. Then go into the TV's setup menu. These vary by model in their choices and the names they use. Find the section of the menu that deals with "input" or "home." You're looking for a choice of "cable" and "antenna." Choose "antenna." There will also be a selection that tells the TV to "scan" for channels. That's what you want it to do. Typically this takes anywhere from 30 seconds to a couple of minutes. Once the TV has found all the channels available, you can exit the menu. From then on it's a simple matter of using your remote to choose the input you want to watch at that time: TV (from the antenna); Cable (if you have a box plugged into another input); DVD etc.
A note on antennas: indoor ones tend to have VERY limited range. They will get reliable reception only on local stations with high-power transmitters. My brother lives in Maine, miles away from the nearest tower, and his indoor got just one station consistently, but with lots of dropouts. A $35 outdoor one got four, three of which were reliable. He bought a better one for about $90 and now he gets 7 or 8, all but one of them consistently.
May 23, 2014 | Audio Players & Recorders
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
Trying to set up Pioneer 5080 HD for use with NO CABLE. Digital amplified indoor antenna? I don't have the owners manual or the remote.
good luck as almost impossible without the remote to do much with this set, the manual you might be able to google.
Sep 03, 2012 | Pioneer PDP-5080HD 50 in. Plasma HDTV
Why can't I get reception on my TruTech tv model DW19TT even after plugging in a Phillips digital indoor tv antenna
If the antenna is working and you are not receiving a signal, then you could have a bad tuner, use a tuner from a VCR , connect the ant to the VCR and go from the VCR with Video cables and go to the Video input on the TV and put your TV in Video mode. That will work.
Nov 26, 2011 | Televison & Video
MY TV only goes to channel 3 and dvd mode and i dont have the remote that came with it can someone help me.
walmart, universal remotes from $7.00 and up, the problem should be that channels up to 3 were blocked and you need to re program channel search on menu, cable or antenna option and then, locate channels with signal, if you watch tv from cable, the channels search only detected the channel 3 as a channel with signal, if the tv is not hdefinition, you wont need more channels, if it is hd, there is an option for dvd, antena (hd signal of course) and hdm or whatever signals capability, I hope I helped you, othewise, contact me and I will be more than happy to help, God bless
Jan 26, 2011 | Philips 25PS40S 25" TV
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
Mar 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Cable to Antenna Issues
You would need to purchase a universal remote, and once you program the universal you would be able to change from cable to antenna or vice versa.
Although there is a slim chance that in the setup screens on your TV (if you can access them by pushing a button on the tv) would have a selection where you could change the 'input' that is selected. If that is not an option, then it is definitely time for a universal remote.
Jun 23, 2008 | Daewoo DVN-14F6N 13" TV
Televison & Video Logo
192 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
