Question about Shure PGX14/20 Professional Headset
Headset stops working
We have Shure PGX 14/20 headsets that we use with Pro Audio Two Way speakers as part of our exercycle "spinning" program, which uses music as part of the exercixe program. The headset works fine for about 5-10 minutes and then stops working completely and I have to yell at my students for the remainder of the class. I have repalced the headset once and that didn't correct the problem. Any suggestions on what my problem is or how I can troubleshoot it? Thanks a lot.
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
There are many, many things that could cause this symptom. You might need to send it to Shure for repairs. I'd suggest calling Shure Support at 847-600-8440 for assistance in troubleshooting.
Posted on Sep 07, 2010
It wont play sound through ps3 the system finds the headset the microphone works but not the speakers
you need to access the audio device settings in the acessory menu and set both input and output to the same device ok :)
Feb 16, 2011 | Logitech ClearChat Pro USB Headset
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
No audio out of the left side headset Shure SCL4
There's not much to repair on these. I'd suggest sending them to Shure. They will replace them for a nominal fee. www.shure.com/service
Jul 13, 2010 | Shure i4c Headset
My pantech reveal's speaker has suddenly stopped working. I cant hear anything when i receive or make calls. A headset icon popped up to the left of the battery icon during the same time the speaker...
it means you have the phone in headset mode so it is sending audio to headset not speaker ...should be able to turn it off in the phone settings
May 25, 2010 | Cell Phones
Simultaneous audio through headset and regular speakers?
This is not possible with Windows. You would need to purchase a mixer program of some sort. The USB headset is seen by the Operating System as a stand alone sound card. Windows will not mix two sound cards.
Mar 07, 2009 | Logitech ClearChat Pro USB Headset
Want to turn off logitech headset and turn on monitor speakers
I know this works on Windows XP:
Settings -> Control Panel -> Sounds and Audio Devices -> Audio Tab
Select your normal input/output from the dropdown list (not the one that says Logiteck USB headset)
Important step - Close the program you were trying to change the audio for, and open it again. It should work. If not, leave it for a minute and try again.
Feb 21, 2009 | Logitech ClearChat Pro USB Headset
Wireless Microphone low volume
The PGX1 bodypack has a switch on the side to set the gain. Make certain that switch is in the "mic" position. Otherwise, simply turn up the volume on your mixer.
Jan 24, 2009 | Portacom Porta-Com COM-60FC 6 Headset...
Shure wireless headset microphone
The most likely problem is a bad connection between the jack and the internal PC board. If you can solder, you may be able to resolve this yourself. Be careful NOT to alter any of the internal coils. Try resoldering the connector and update this if that fails to resolve the problem.
Dan
Jul 29, 2008 | Audio Players & Recorders
Shure PGX14/20 Professional Headset Logo
71 people viewed this question
Top Shure Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Shure Radio Communication Expert? Answer questions, earn points and help others
