Question about AEG 34942G-M Gas Cooktop
The pins which locate the pan stands on my AEG gas hob
The little pins which hold the pan stands in place on my AEG 5 burner gas hob have broken, allowing the stands to move or slide, which is dangerous when pans are standing on them.
The pins are located at the rear of the hob, and they fit into holes on the pan stands
Is is possible to replace the pins?
4 Suggested Answers
  • 1462 Answers
SOURCE: AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Posted on Jun 16, 2007
SOURCE: small pans do not work.
are you sure the small pan is made of conductive metal , ( used the magnet test ?)
Posted on Apr 04, 2009
SOURCE: Aeg hob
Thank you thank you thank you to the Apprentice... the user manual for my 6410KFN hob gives the WRONG instructions to turn off the child lock!! The Apprentice has it CORRECT!! Legend!
Posted on Apr 25, 2009
Gas hob igniting but not staying on
Make sure all the little gas holes are clean. After a while food and dirt will plug those little holes and not let the gas flow properly on the burners and pilots.
Apr 21, 2015 | Cooktops
My Neff T67S76NO hob has a Wok burner problem, I think. The inner ring flames are fine but the outer ring can't be turned above half on before the flames start to go ragged. The more it's turned up th
it sounds to me that u need to reduce pressure although u say pressure is correct try reducing pressure and see what happens i presume u use bottle gas L P G?............in any case the flame shud not ever lift of burner and flame doesn't need to touch pan to cook hope this helps
Jan 07, 2014 | Cooktops
Gas hob keeps sparking all the time
check the ignition button or its wiring, the button may be broken and 'on' all the time, or the wires underneath broken off and shorted together.
Jan 18, 2011 | Rangemaster Professional 4 Burner Hob 23...
One igniter produces no spark. is it bad? can i
Looks like you may have a bad ignitor. Try adjusting the arc gap. Sometimes of the ignitor is too close to the burner, the ignitor will not spark. It may also be that te burner is dirty and needs a little cleaning to allow for the electric ignitor spark to arc accross, thus producing ignition. Good luck.
Jul 14, 2010 | AEG 34942G-M Gas Cooktop
Turn hob on and only get letter L on each hob and will not turn on
child lock is activated , switch on hob press - and + button simultaneously hob will return to normal. if zeros dont appear try pressing and hold - key slightly before pressing +key hold both for a few secs.
Jun 23, 2010 | AEG 23 in. 6410KF-N Electric Cooktop
Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Jan 09, 2009 | Cooktops
Small pans do not work.
Dec 13, 2008 | AEG 23 in. 67600KF-N Electric Cooktop
Gas Hob Flame
Hello
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
AEG 34942G-M Gas Cooktop Logo
44 people viewed this question
Top AEG Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you an AEG Cooktop Expert? Answer questions, earn points and help others
