Question about Frigidaire PLMV169DC Microwave Oven
The bottom hinge has apparently broken free from the body of the microwave on the inside (The door still shuts). How is this repaired?
  • 32 Answers
It isn't. Frigidaire m/w hinges are usually spot welded to the cabinet. can't be repaired.
Posted on Dec 28, 2010
How to repair a broken lower door hinge?
You may need to remove the microwave off the wall but lets try this first. Unplug the micro and then remove the screws around the bottom cover plate. The cover should drop down--watch the wiring to the light system mounted to the cover. Now look at the bottom hinge area. Can yo see and access the screws to the hinge??? Should be 2 or 3 screws. If you can get to them then you can change the hinge there. Tape the door in place so it doesn't drop while doing the repair. If you can't see the screws, you may need to pull the micro off the wall and remove the outer case to do the repair. In some rare cases the hinges are welded to the case and not replaceable.
Mar 30, 2015 | Frigidaire PLMV169DC Microwave Oven
Microwave door sags
I had the same problem. An easy fix is to remove the door by opening the door, take a screwdriver and pop the plastic retainer piece from just below top hinge on the door. Now lift the door gently and it will come off in your hands. Set aside and be careful not to let the loss bracket that passes into the microwave body fall back into the cabinet. I would suggest you use a small vice grip locked onto that bracket to keep from lossing it inside. You will see two holes, one near the top and bottom through the cabinet into the hinge. line these holes up with the hinge holes behind them and use a pop rivet gun and 3/16" rivets to lock into place. Then replace the door and retainer piece. If you only have 1/8" rivets you can hold the bracket lined up with the original holes and drill 1/8" holes of your own a little distance away from the original holes and then pop rivet through these holes.
May 12, 2010 | Frigidaire GLMV169D Microwave Oven
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
Frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
Mar 10, 2009 | Frigidaire GLMV169D Microwave Oven
Signs of burning on inside of plastic door surround .
replace plastic inner and check any rust is there, check inside body and compleat door.
Nov 12, 2007 | Bosch HMT9626GB Microwave Oven
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Removing the microwave door
In many cases, microwave door panels are held together by hidden hooks or catches that ave to be separated by a thin, strong tool such as a putty knife. I've attached a photo that should serve as a good example.
Apr 16, 2007 | Neff H7871A2GB 800 Watts Convection /...
Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
May 14, 2006 | KitchenAid KEMC377K Convection / Microwave...
Loose door handle
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
Apr 28, 2006 | GE JVM1330BW/WW Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
633 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
