Question about Minolta bizhub 350 Black and White Copier
Konica minolta bizhub 350 error code c5352 the machine is not workking now plzzzzzzzzzzz helpppppppp
  • waelalhadad2 Feb 11, 2010
    thank you for answering me
    my problem
    whin I turn on the machine after warming up
    the error code appear
    malfunction detected please call your technical representative
    c5352
  • sam gerban
    sam gerban May 11, 2010
    could you please check the cod again??
  • Minolta Master
  • 6,674 Answers
Cooling Fan fault. To clear open and closer the front door.
Posted on Apr 04, 2010
    New Friend:
  • kode error c5352 dan kertas tidak naik saat kopian solusinya gimana
Posted on Oct 20, 2016
I would like a list of error codes for the Konica Minolta bizhub 350
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C350
Apr 14, 2015 | Konica Minolta bizhub 350 All-In-One Laser...
C0862 error code on Konica Minolta Bizhub 250
Sir could not find that code in the machine service manual.
Mar 07, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Error code konica minolta bizhub 350
Sir which is it the Bizhub 350 or the Di2010 to different ways to clear the C0500 code.
May 21, 2013 | Minolta Office Equipment & Supplies
Error c-0200
konica minolta bizhub malfunction detected error code c-0200
Sep 01, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
Error C11A3 Konica Minolta BH 350
solution for error code c11a3 konica minolta bizhub 350 machine
Jul 21, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Cooling fan check the rear of the machine. Looking at the back lower left side remove the rear panel top pane has to be removed also there is a filter with that fan due to age got stuck in the fan remove it blow out fan with air, tape the filter to the metal frame instead of putting it on the fan frame out or inside. or the fan is bad worse case the control board is bad$$$$
Jul 17, 2012 | Minolta bizhub 350 Black and White Copier
C-5354
Cooling Fan Motor Failure. Can't tell you which one tho as the factory service manual shows C5351, C5352 and C5353 but does not list a service code C5354. If by chance it is one of the other codes then let me know and I can tell you which it is. Minolta's throw cooling fan codes sometimes. You can usually reset the code will "bumping" the machine and they will at least run ok until the motor stops in the "dead spot" again.
Good Luck and Thank You for using Fixya.
Jun 03, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Apr 15, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Minolta bizhub 350 Black and White Copier Logo
2,052 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
