Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
How to unlock the child lock
I can't start my Whisper Quiet Plus Kitchen Aide because the child lock is stuck on.. can you help me.
    Loyalty:
    Visited the website for 30 consecutive days.
    Dedicated:
    Visited the website for 20 consecutive days.
  • 18 Answers
Most of the dishwasher in this series have an energy saver dry button. Hold this button in for four seconds and it should unlock the child safety lock. Does not work, try again for 30 seconds. Does not work. We have problem. If your model does not have an energy safer button, then type in the model number and you should be able to find the manual online and open the same to find out how to unlock the child safety lock. If all fails then you need an Electronic control board assembly, about $86 for your model, plus shipping from repair clinic.com. If you are at all handy, this is easy repair. Make sure you turn off the breaker or remove the fuse before you attempt any repairs.
Posted on Feb 20, 2010
  • 4 Answers
Okay so I tried the 4 second hold down on the "Energy Saver Dry" Didn't work. I tried 20 seconds...Nope. I held it down for 1 full minute...Nothing. Finally I gave it one last shot before calling the Repair Man. I held the "Energy Saver Dry" and The "Cancel" Buttons down together for about a Minute. The "Child Lock" Light went out. I hit "Start" and WALLAH !!!!! It worked. Saved a few bucks by my determination...GOOD LUCK.
Posted on Mar 24, 2012
SOURCE:
Whisper quiet plus kitchen aid manual
Hello, As You Wish -
It looks like you can obtain the owner's manual for your Kitchen Aid dishwasher through the Kitchen Aid web site. It will probably be a download option for a PDF version of the manual. This is the link: https://www.kitchenaid.com/customer-service/manuals/ . You will need to enter the model number of the dishwasher.
Note: When I obtain a downloaded PDF user manual (for anything), I create a file in my Documents folder, giving the file the name of the product, so I can find it easily. Example: Kitchen Aid Diswasher. Unless the manual is hundreds of pages long, I also print it out and keep it in a paper file folder with other appliance and equipment user manuals.
Best wishes.
Dec 18, 2017 | Dishwashers
Kitchen aid dishwasher whisper quiet model door stuck closed
I found this on another site hope it works for you.Take a bamboo shishkabob skewer and look were the handle is underneath the plastic console head unit and place the skewer on the right hand side... angle towards the center of the console and wiggle it in and push up...After i thought of the skewer it took me around a minute to push the latch up.
Read more: http://appliancejunk.com/forums/index.php?topic=5096.0#ixzz3Yhgf8Ihd
Feb 24, 2015 | KitchenAid Kitchen-Aid KUDD03DTSS...
Kitchenaid whisper quiet plus dishwasher
It is likely the thermal fuse is cut off and will need to be reset or replaced depending on the model number of your dishwasher. Please provide actual model number in the comments.
Apr 25, 2014 | KitchenAid Dishwashers
My kitchen aid whisper quiet dishwasher will not start and the clean button is flashing
The flashing clean light is an indication that the water did not heat properly. Follow the link below to some instructions I put together that will show you how to reset the control so you can use the dishwasher again and what may have caused the error. Let me know if this is helpful.
Clean Light Flashing
May 22, 2010 | Dishwashers
Child lock to turn off
Well you can please follow the below steps -
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Good Luck!!
Thanks
Mar 02, 2010 | KitchenAid Dishwashers
Child lock blinking on a Kitchenaid ultima diswasher.
Try holding the E.S. button down for 30 seconds. Does not work, you need an Electronic control assembly which can be ordered online from Repair clinic .com for $146 for your model plus shipping. This is apparently a common problem with Kitchenaid dishwashers. Just repaired one the other day. Tried everything, but as soon as the new Electronic control assembly was installed, everything was Okay. This is an easy repair for anyone who is handy at all. Please shut off power to the dishwasher by switching the breaker off or removing the fuse.
Feb 04, 2010 | KitchenAid KUDR25 Dishwasher
Kitchenaid Whisper Quiet + dishwasher making loud humming noise
Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
Jul 14, 2009 | KitchenAid Dishwashers
Kitchen aide won't drain
look in your air gap first make sure there is no debrie in there this will make you dishwasher drain really slow.
Jan 16, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Oct 19, 2008 | KitchenAid 24 in. KUDS25 Built-in...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
2,332 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
