Question about Frigidaire PLHS237ZD Stainless Steel Side by Side Refrigerator
Frigidaire model PLHS237ZDBA Ice maker dispenser won't switch back to cube ice it keeps crushing ice though its on Cube ice?
The rod under the ice tray was not in the correct position when the tray was inserted back into the freezer after removal. I get cubes now.
Posted on Feb 09, 2010
Why does my cube ice does not dispense ice?
Check to see if the actuator is lifting up. sometimes these freeze and won't lift the arm that releases that grinding blades. It is in the back panel behind the ice bucket. Remove the bucket and hit the light switch. Then hit the ice actuator flap on the door and see if the little "stirrup" looking thing jumps up. There is usually a clicking sound when it lifts. it could be frozen or just bad.
Jul 23, 2014 | Frigidaire Refrigerators
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
Aug 17, 2009 | Refrigerators
Ice dispenser only dispensed crushed ice, not cubes.
there is a metal rod that sticks out the back of the ice maker bin, it has a spring around it. it needs to fit into hole in the back of the fridge.
May 17, 2009 | Frigidaire PLHS269ZD Stainless Steel Side...
My ice-maker keeps switching to crush on it's own.
There is a long rod on the right side of the ice dispensing bucket.
This rod goes through a hole in the back wall of the freezer where a solenoid should pull up on the rod allowing the ice cubes to dispense without being crushed.
If this solenoid goes bad or ice forms around the plunger, it cannot pull up on the rod.
Check out that solenoid and the rod assembly.
https://www.repairclinic.com/Frigidaire-Refrigerator-Parts
appliance parts, help & more
Apr 13, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
ICE Maker stuck in dispensing crushed Ice
That means that the evaporator fan system that releases the the ice cubes is not working.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Nov 29, 2008 | Frigidaire GLRS267ZC Side by Side...
Frigidaire PLHS237ZD Stainless Steel Side by Side Refrigerator Logo
256 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
