Question about Dishwashers
Kenmore dishwasher model 665
I cant get my rinse aid to dispense.
  • magamay Feb 23, 2008
    The rinse aid is still as full as it was when I filled it over 5 months ago. Could I have overfilled it? There is no mark that shows you what the maximum amount is.
    President:
  • 2,651 Answers
Rinse aid generally dispenses automatically in cycle, very small amount every time. why do you think its not dispensing?
Posted on Feb 22, 2008
I have a kenmore elite ultra clean dishwasher. Have only used it two times. Does not dry well. Lots of water left Read Manuel. Extra dry should not always have to be used. Water still on door after a...
RINSE AID! Buy a bottle of Jet Dry or similar rinse aid liquid. Fill the rinse aid dispenser completely. Run dishwasher as usual. Water will no longer cling to the tub or the dishes. Newer dishwashers require rinse aid to dry properly due to reduced energy consumption.
Aug 07, 2014 | Dishwashers
Dishwasher Rinse aid
Yes its the right side of the soap dispenser.Turn the dial there ccw and fill with rinse aid
Jun 14, 2013 | Dishwashers
The dishwasher doesnot dry anything.
  • Check the rinse aid indicator beside the rinse aid dispenser cap. If the indicator window is clear, refill the dispenser. The dishwasher will retain moisture and the heat dry option will not perform properly without rinse aid. Turn the dispenser cap clockwise and lift it up to remove it. Pour rinse aid into the dispenser until the indicator appears full. Place the dispenser cap over the dispenser and turn it counterclockwise to tighten it.
  • Load the dishes properly so that all dishes can drain after the rinse cycle. Do not overload the dishwasher. Towel-dry plastic dishes because they will not dry completely during the dry cycle.
  • Select the heated dry option on the dishwasher. The air-dry and energy-saving dry options will not perform as well as the heated dry.
  • Oct 10, 2010 | Whirlpool Dishwashers
    My Kenmore Elite dishwasher gives a message "Rinse Aid Empty". What does this mean?
    It means the rinse aid dispenser is empty.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    May 10, 2010 | Kenmore Elite 45986 Front Load Washer
    We have a Kenmore dishwasher model #665 15831971
    4 step check
    1. make sure the in coming watter is hot. solet the faucet run until this is so.
    2.add or completely fill rinse aid .open and close door 3times then fill somemore that will take the air out of dispenser andallow you to completely fill dispenser.
    4. add correct dishwashing soap
    once you did all of that your problem should be gone. let me know if i have been of some help.
    Feb 26, 2010 | Dishwashers
    Dishwasher rinse-aid dispenser not working
    the film is caused by hard water. go to www.dishwasherfilter.com. they have a product out for this exact problem. works amazing every time and is very affordable.
    Dec 29, 2009 | Kenmore 24 in. 16593 Stainless Steel...
    HOW TO PUT RINSE AID INTO THE DISPENSER CORRECTLY???
    if you're referring to rinse aid for a dishwasher, just unscrew the dispenser lid, and fill the dispenser with rinse aid, then screw top back on.
    Mar 22, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
    Rinsing detergent from dispenser
    Use gel run a few cycles and help clear and then don't overfill w gel soap
    Nov 13, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
    Dishwasher sending out bubbles
    There is a plastic strip that runs between the lower panel and the upper panel you can pull the strip off then take the outer panel and cardboard out you will see the rinse dispenser there. open the door and take the rinse cap off the dispenser and push all of the plastic tabs in at once and pop the dispenser out. now you can clean out the dispenser and put things back together.
    Dec 18, 2007 | Kenmore 17252 Free-standing Dishwasher
    Dishwashers Logo
    329 people viewed this question
    Top Dishwashers Experts
