Question about Maytag EPIC MFW9700S Front Load Washer
Clothes are still very wet after cycle is over on maytag epic z
  • 21 Answers
U might want to check your water pump take off that bottom panel there are 3 t20 troque bits at the bottom the pump should be in front then u take off the filter on the pump becareful its plastic and check to see if there is any objcets in that filter and check your drain hose two if that does not help u might have to replace the pump... good luck
Posted on Feb 16, 2010
Cloths are wet after spin cycle
ceck for kinks in the drain hose .if you have a wet vacuum try sucking on the drain hose, or fallow the drain hose into the back of the unit to see if there is a blockage or a belt off .. jay florida
Nov 23, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have a MayTag 4000 series washing machine that is 6 month old. Sometimes the water pump is working but then it does not spin. Then one hour later the washing machine finishes the cycle but the clothes...
the problem with the washer is simply the panel or it might be the belt if the machine is not direct drive machine or call ur technician alson to run a check on it
Jun 28, 2011 | Maytag EPIC MFW9700S Front Load Washer
F28 error / water starts to fill then quits in 15 sec's
F28 is a communication error which usually means there is a connection that has come loose.Check the wires on the control board.
Nov 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Epic washer doesn't spin fast. spins, but slowly. clothes coming out wet, very wet. it started after i washed a heavy wool sweater.
Check the filter, make sure rinse hold is not on, check the drain hose is not blocked, lastly check the brushes, remmember unplug first.
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag epic he has F6 code
What is the model number of this unit. Should be inside the door on the frame. If you take off the bottom panel, there is a tech sheet in there that will tell you what that means. I don't know that one off the top of my head and I can't get at my work P.C.right now. It'll give good detail of what to look for on that tech sheet Let me know if you have any questions.
Mar 06, 2009 | Maytag EPIC MFW9700S Front Load Washer
Clothes still wet after final spin cycle
It sounds like you might have a broken belt or the belt just slipped off the pulley!
Jan 22, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Epic Error "F"
I dont know how to fix it but if you hit OFF then start it restarts, i get the same message it will appare over and over again untill the load is done.
Oct 18, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
272 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
