Question about Samsung Washing Machines
My samsung washing machine WA88TPM not starting. Power is ON.
Machine is on but will not run; what could my problem be? Model number WA80V3
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Apr 04, 2015 | Samsung Washing Machines
WHY AREMY POWER BUTTON NOT COME ON WHEN PRESS
www.samsung.com/in/consumer/.../washing-machin...
www.samsung.com/in/info/contactus.html
Sep 08, 2014 | Washing Machines
How to reset my samsung washing machine when stuck?
Unplug 10 seconds an retry . If no sound ck power source , if there is sound ck pump filter may be plugged .
Jun 09, 2014 | Samsung WF337AA Front Load Washer
Samsung front loader washing machine power cut out mid load
If by turning off the power you mean you hit the power button .... try unplugging the machine for about 15 seconds and then plug it back in ... this may reset the machine. If not you may want to call Samsung ...
http://www.samsung.com/au/info/contactus.html Hope this helps!
Nov 25, 2013 | Samsung WF337AA Front Load Washer
Samsung Washing Machine won't start
Your program controller unit is working but it must be ensured that there is output on every cycle to the desired output controls. So the inlet valve must work and the motor must run when the water level is triggered by the level controller. So use a meter to check before we can suspect the controller.
Nov 11, 2011 | Samsung Washing Machines
Model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
May 02, 2009 | Washing Machines
Washing Machines Logo
110 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
