Question about GE Monogram ZISS480DRSS Stainless Steel
Displayed temperature does'nt correspond to measured temp. inside the refrig
The displayed temp does not correspond to the effective temp. measured inside the refrigerattor
motherboard changed and did not solve the problem
if I reset the refrigerator by pluggin out and in AC current the disply works for about 30 minutes and the compressor is active
sometimes we find water coming out from the freezer
the compressor works normally the tecnichian said
the water filter has also been changed
thank you for your help
Vincenzo
    Scholar:
  • 121 Answers
Hi..
It looks as if you need to have the drain cleaned due to your freezer leaking water issue. I've seen this issue b4 but it will be a little work to do so if you can find an experienced repairman, then let him do it bc it gets messy sometimes.. it could cost around $200 so i would definitely ask the tech guy on the phone about the drain and if you could do it.. good luck..d
Posted on Feb 22, 2008
    Genius:
  • 3,422 Answers
To fix the water leak u can try doing the below method.
BLOW AIR THROUGH THE DRIAN HOSE IN THE BACK OR BOTTOM OF THE FRIDGE FIND THE END OF THE DRAIN HOSE USE AIR COMPRESSOR .....
Here is another solution:
inside of freezer, take back cover out and thaw the ice with hair dryer or hot water. don't use any sharp tools. When thawed make sure water drains through defrost drain.
Goodluck..
    Master:
  • 788 Answers
Sounds like there is a bad thermistor (sensor) somewhere.
Why is my outside temp not registering. I have replaced the batteries
  • Remove all batteries
  • Install outside batteries
  • Move from outside to inside at a casual pace to allow time for outside unit to begin sending temperature
  • Install inside batteries. You should see outside temperature displayed
I find that outside temperature display comes and goes depending upon the weather, e.g., Today at 12 pm, the outside temperature is 35 deg F; earlier this morning it was - -. For the last couple of days, the temperature has been - - then suddenly last night it was 28 deg F.
Jan 30, 2017 | Measuring Tools & Sensors
Differential between settings and actual temperatures?
Do you mean there is a difference between the actual measured temp of the space and the space temp as displayed on the stat? If so, there should be an offset function on the stat that can be adjusted. The location of the stat should also be considered. If it is on an exterior wall it could be sensing the temp within the wall cavity. If it is located in direct sunlight this would also effect the display temp.
Jan 08, 2015 | Honeywell RTH6400D 5-1-1-Day Programmable...
The temperature on my refrigerator keep going up It is now at 72 and the freezer side is at 49
If the inside of the unit measures at the same displayed temp, then you have a coolant issue = contact professional immediately.
If the temp does not match the display temp, you have a control board issue = still contact a professional.
Aug 16, 2012 | Frigidaire FRS3R5EMB Side by Side...
Temperature fluctuates in bake setting. Temp on display does not match real oven temperature.
as long as your measured temperature is within 15-25 degrees of shown temp, then it should be ok. remember the temp in the oven will be different from top to bottom.
Dec 11, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
Indoor temp is 5 degrees colder than display reads on digital thermostat
Where are you measuring the indoor temperature?
To compare it to the thermostat temperature you have to measure both temperatures at thermostat.
The thermostat will only control the temperature at the thermostat, not any where else in the room.
The room temperature depending on insulation in walls and ceiling and distance from outside wall and outside temperature, can be as high as 10° difference from outside wall to inside wall of house.
The lower the outside temperature, the greater the room difference in heating. The higher the outside temperature the greater the room difference in cooling.
Feb 13, 2010 | Honeywell Programmable Thermostat Heater
GE PROFILE REFRIGERATOR MOTHER BOARD PROBLEMS i REPLACED THE MOTHERBOARD AND IT STILL DOSEN'T KEEP THE PROPER TEMPERATURE. It varies from 36 to 45 degrees.
Go into the diagnostic mode on your touch display .
1) . Press any button on the display 1 time except the temp adjust buttons.
2) Press the temp up and down on both the freezer AND refrig (all 4 at the same time)
3) when 0's show , release the buttons and press any button except for the temp adjust buttons .
4) NOW , fress the temp adjust buttons until the freezer side displays 0 and the refrig side displays 7 . 0 and 7 is for the thermistors test .
5) After 0 and 7 display , press any button again except temp adjust , and this will start the thermistor check .
6) You will have 7 thermistor tests , indicated on the refrig display , starting at 1 , then 2 then .......
7) The feezer display will tell for the corresponding thermistor , indicated by the refrig display , if the thermistor p = pass , s = short , b = bad (replace board)
After determining if or which thermistor is bad , then adjust the display to 1 on freezer display and 6 on the refrig display . This ends the testing procedure and resets the refrig back to normal .
Sep 26, 2009 | GE Profile PFCS1NJWSS Stainless Steel...
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
1999 VW Beetle outside temp display not working
For general awareness, the outside air temperature sensor is located above the inside mirror.
Try to reset the temperature measurement unit: 1. Switch engine on. 2. Press and hold clock minute (min) and hour (h) buttons simultaneoutly longer than 3 seconds. The display will show new temperature measurement unit.
Apr 03, 2009 | 2000 Volkswagen Beetle
Operation of digital temperature indicator
When the unit is idle and in a wash cycle the wash temp is displayed.If you look inside the tank you will see a white float and a metal probe which is the themometer for the wash tank temp.The rinse temp will only be shown when the display reads (Rinse) and theres a thermistor that screws into the water line near the solenoid valve that measures the temp.
Feb 17, 2009 | Hobart AM14C-155 Dishwasher
GE Monogram ZISS480DRSS Stainless Steel Logo
67 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
