Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
My Honeywell 3 port valve in my CH/hot water systemis not working
I have a Honeywell motorised valve in my CH/hot water system. I dont think it is working as it does not move and there is no resistance in the lever. The hot water still heats up when the CH is on and the Hot water is not being asked for, There are five wires to it but I dont know which wires do what. Is there an easy way I can test it to see if it is working and check if the wiring to it is correct. Thanks Dave
  • Honeywell Master
  • 2,558 Answers
Hi two things that go wrong inside the valve gets clogged up and blocks up in side, the valve in side and get worn sorry 3 things the motor on the top burns out , if you remove the top cover you will see a small motor with 2 orange wires on it you can remove the motor with 1 screw and see if its turning
Posted on Feb 08, 2010
How do I fix central heating
The first thing you need to substantiate is the fact that there is enough water in the system. It will be a closed loop system requiring approximately 10 psi/ floor. (Only a rule of thumb). Usually when one protion of the system works and the other does not, it is an issue of water quantity available to circulate through the combination of loops. If you have to add water, you will probably have to purge air from the highest points in the system. Even if there is an "Airtrol" fitted in the bottom of the expansion tank, bleeding the high points will eliminate air quicker.
The hot water portion of the loop should only be going through a heat exchanger that transfers the loop temp to the domestic water circuit and the three way valve is probably a 'mixing valve' utilized to maintain a certain loop temperature on the primary loop.
Dec 01, 2014 | Honeywell Heating & Cooling
Heating and hot worker work separately but not together
If this a honeywell valve you may need to change the motor in side the valve , sounds like its lost some of it power to move the inside of the valve to y postion .
Nov 04, 2012 | Honeywell Programmable Thermostat Heater
I think my motorised valve is not working. I replaced the thermostat, have it down to 55 and there is still 70 plus temps in heat. system is 3 zones. i bought the replacement honeywell unit today. the...
I am having a similar problem mine will not shut down but what I understand from the service man is the valve should work on Automatic... manual is for a defective valve and you can force heat through by setting it on manual...
Jan 18, 2011 | Honeywell Heating & Cooling
My Honeywell ST 6400C won't heat the hot water the light comes on but pump doesn't run or boiler fire. But does work on C/Heating.I can get hot water only by running the C/H and manually opening the hot...
it sounds like the motor in the motorised valve is not working on some models you can just change the head /motor , check cylinderstat (hot water stat) is working
Dec 14, 2010 | Honeywell Heating & Cooling
I have hot water returning to the normally cold header tank. All rads get got I have turned the pump speed down. Both outlet pipes from the 3 port valve are hot, the valve does not make a noise when...
Hi yes it could be the valve has stuck closing the return part of the valve turn heating off try hw only return should warm up , try gentle taps on the side off the valve might free it
Feb 21, 2010 | Honeywell Electronic Programmable...
Ideal boiler no heat to radiators but hot water still working
check the divertor head and valve.
sounds like it ist adjusing from dhw to ch.
take head off(remove pi at back,or side pin) and push pin in valve when calling for ch,if it works then the head has gone.
Nov 19, 2009 | Honeywell Programmable Thermostat Heater
Hi There, I have an Ideal Response 120 Combi Boiler. Each day the water pressure falls to 0 on the pressure gauge. In order to get hot water and Cental Heating I increase the pressure to 1.5. The Hot water...
I have the same boiler with a similar issue. The water is more than likley leaving the system from the pressure relief valve, which will be routed outside. It sounds like you have lost the pressure in your expansion tank, which is inside the boiler. With the boiler pressure at zero and the power isolated, the expansion tank can be accessed from a panel at the top of the boiler on the right hand side. You will see a valve on the red expansion vessel like the one on a car tyre and can be pressurised with a car tyre air pump. I think from the manual the pressure should be about 1 bar, but it depends on the length of pipework on your system. A competent boiler engineer should be able to sort this out, but it may be that your valve is leaking, or the expansion vessel has failed and the problem will occur again.
Nov 10, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
How to wire in a honeywell 9400c timer clock 4 ch
One of these wires is contains permanent live, neutral and earth. The other wil be heating on and hot water on, the earth on this wire will probably not be used.
you will have to trace the wiring back or test it!! Be carefull!!
Dec 11, 2008 | Heating & Cooling
Heating & Cooling Logo
343 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
