Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer ""walks" when in the high speed cycle. Tech says it is a problem with the floor not the machine. I made sure the machine is level - I had previously asked this question but did not save the ansswer but did someone say there was a devibrator or something that can be looked at if you take off the back of the machine??
  • 15,935 Answers
It appears your vibration damper has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#####
Posted on Sep 30, 2010
What will cause my Whirlpool washing machine to set on low speed spin cycle?
The machine uses automatic load sensors to balance the load and when you put something in the machine that is big, like a comforter, it knows that it cannot balance that item. So with a front loader it wont spin at high speed because it would be off balance and either damage the machine or the machine would "walk" because of the off balance motion.
Apr 28, 2014 | Whirlpool Washing Machines
My whirlpool duet washer stops towards the end of the cycle and flashes 6 then F. The door stays locked and the washer beeps. It has happened before, the machine is about 6 years old, how can I fix
F/06
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Feb 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Duet bounces across the floor during wash cycle!!!
yes , first make sure your machine is balanced , and if you want to risk it to check the springs all you have to do is remove the top and check if one of the springs is longer thet the other or if tub is **** eyed, I am assuming you removed the shiping bolts before connecting your washer.
also your frame or base might be dammaged from shipping.
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer in high spin cycle "walks" slightly away from the wall although when I put a level on it it appears to be level. The floor vibrates when it is in this high spin cycle. Feet are not raised very much...
make sure all the pegs are touching the ground. You may have the vibration dampner going out or the weight on the wheel is loose. You can find all that by unscrewing the back of the machine
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tub squeaks and washer walks around floor during cycle
did you remember to remove the retaining bolts/screws located at the rear of the machine?
Oct 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer vibrates and walks across the floor
Theres a few things you can do to stop it from walking.
but the best way i know is to use washer anchors.
Whirlpool part# 155P3 $22.95
Im going to assume that you have eaither the wfw8300 or wfw8400
the main differences is the suspention system in them. the 8300 uses a 5 point system that work but really you should only use the washer on solid flooring like concrete. the 8400 uses a 6 point with better shocks.
if you have this washer on a main floor with basment underneith it you might want to check the floor. grab a glass of water when it starts to shake and walk and put it on the floor, if the water is jumping then the floor is the problem.
eaither way the anchor kit i have listed above will stop your issues with it moving and walking.
Feb 07, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Washer is "walking" during the spin cycle
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool frontload duet washer F 6 problem
hello cjkcp
Welcome to Fixya
You said, your washer (now 4 yrs old) occasionally stops mid cycle flashing F 6 code. Is this something we can fix or do I have to call a repair man?
F/06 Drive Motor Tachometer Error
  • Check the MCU
I believe this needs a hands on tech to daignose this. Unless you feel you undrstand the problem your self?
Thank you for using our service for advice.
Please remember to leave a rating!
Huuum
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Duet Washing Machine spin cycle is spinning slow
make sure u are not under loading the washer with just one or two items and that the load is fairly balanced or else the machine will not go into high speed spin as to not go completely off balance and walk across your floor if that doesnt fix it you might need a new ccu or motor control board probably the second one and make sure u are using HE detergent and not too much because suds will lock the pump up which will not spin with water in the unit
Mar 19, 2007 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
