Question about Toshiba Laptop Keyboard for Satellite L10, L15, L20, L25, Tecra L2 Series
How do I replace the keyboard on a Toshiba Satellite L25-S1215 laptop?
    Scholar:
  • 59 Answers
1) Disconnect power and remove battery.
2) Remove the screws indicated in red behind the hinges on the laptop (on the back side above the battery location) As seen in this pic:How do I replace the keyboard on a Toshiba - 2d7ab9f.jpg
3) In the battery compartment area unscrew the screws circled in red. Then open the laptop screen slightly so that the whole laptop is in an upside down "V" shape. Unhook the plastic tabs circled in green. As seen in pic: 685d923.jpg
4) Open the screen all the way so that it is parallel with the main body of the laptop. Gently take off the plastic piece above the keyboard by lifting it up in the areas indicated by the yellow arrows. AsHow do I replace the keyboard on a Toshiba - d17b74a.jpgc: d17b74a.jpg
5) Lift out keyboard and remove ribbon cable from connector. Be careful not to break cable retainer/tensioner. As seen and described in pics: (first pic isHow do I replace the keyboard on a Toshiba - 52e6593.jpgee after lifting keyboard)
(ThisHow do I replace the keyboard on a Toshiba - 0f78500.jpg shows and describes how to remove the cable safely from the connector)
6) After connecting new keyboard, reverse the order of steps to assemble.
I hope this is enough detail to help you get the keyboard replaced
Posted on Feb 08, 2010
I Want The Drivers of my Laptop. Details are as follows... (Toshiba Satellite L25-S119)
The Toshiba web site has all you need.
Just enter your model number and follow the prompts. The web site can even get all the information from your Satellite for you if you are not sure.
Click here.
Oct 23, 2010 | Toshiba Satellite L25-S119 Notebook
Is there a place that shows how to replace a keyboard on a toshiba l25 1184 laptop
this link shows how to replace keyts, but once you go to this link, you will find other videos on how to replace Toshiba keyboard
http://www.youtube.com/watch?v=7lfIEreAGHo
Oct 20, 2010 | Toshiba Satellite L25-S119 Notebook
Touch pad problems
Most of the toshiba laptops can disable touch pad with FN + F9.
In F9 key u can find touch pad picture.
May 27, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
I have a Toshiba Laptop Satellite M505-S4940. The
the only way to get rid of this is to replace your built in keyboard....!
May 12, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
Need a manual for toshiba satellite L25-S1216
May I know your email add, and I will send the manual over there for you,
Thanks
Let me know here again.
Aug 20, 2009 | Toshiba Satellite L25-S119 Notebook
How can i recover my laptop to factory settings?
Applicable Models: Satellite L15-S104, L15-S1041, L20-S310TD, L20-SP231, L25-S119, L25-S1194, L25-S1217, L25-S1213, L25-S1215, L25-S1216, L25-S1196, L25-S1211, L25-S1214, L25-S1212, L25-S121, L25-S1193, L25-S1192, L25-S1195, L35-SP1011, L35-S2366, L35-S2316, L35-S2206, L35-S2194, L35-S2174, L35-S2171, L35-S2161, L35-S2151, L35-S1054, P100-ST7111, P100-ST9212, P100-ST9712, P100-ST9742, P100-ST9772, P100-ST9762, P100-ST9752, P100-ST1072, P100-ST9732, P100-ST1071, P100-ST9412, P100-ST9612, P100-ST9012, P100-ST7211, P105-S921, P105-S931, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6034, P105-S6024, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6074, P105-S6054, P105-S9312, P105-S6014, P105-S6002, P105-S6004, P105-S6012 << hideThe printed instructions included with the Recovery and Applications/Drivers Media disc are correct for most computer models. For some models, however -- including those listed above -- booting from the Recovery disc requires pressing the F12 key, rather than the 'C' key. The instructions below are correct for these models.
CAUTION: The Recovery process reformats the computer's hard disk drive, which completely erases its contents -- including all applications, all documents, and all other data stored on the drive. Be sure to back up your documents and other data before following the instructions below.
Follow these steps to erase the current contents of the hard disk drive and to re-install all of the software that was installed on the computer when it was manufactured:
1. With the computer on, insert the first Recovery disc into the optical drive.
2. Shut down the computer (click the Start button, click Shut Down, select Shut Down, click OK).
3. Press the computer's power button to turn the computer on, and then immediately press and hold the F12 key. Release the F12 key when the menu of boot options appears.
4. Use the arrow keys to navigate to the CD/DVD option. Press the Enter key to select it.
The computer will restart, and will boot from the Recovery disc.
5. Follow the instructions on the screen to start the Recovery process.
CAUTION: Once the Recovery process has begun, do not interrupt it.
The computer's hard drive will be formatted, erasing its contents. All of the software that was installed on the computer when it was manufactured will then be re-installed.
6. Once the Recovery process is complete, remove the Recovery disc, and press any key to restart the computer.
- mc/wa
Jan 27, 2009 | Toshiba Satellite P105-S6207 Laptop
Recovery disk for my laptop
If it is the drivers you require the Toshiba webite should have them. If you call them with make/model seriel # they may be able to provide you with a replacement recovery disk. Hope this helps.
Dec 24, 2008 | Toshiba Satellite L25-S119 Notebook
Keyboard- the right side keys
open up the unit again, and make sure the cable connecting the keyboard is seated precisely right in the connector..this can happen sometimes..
Mar 09, 2008 | Toshiba Satellite L25-S119 Notebook
Toshiba Laptop Keyboard for Satellite L10, L15, L20, L25, Tecra L2 Series Logo
318 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
