Question about Vizio P2 42 in. HD-Ready Plasma Television
Vizeo 42 hd plasma tv (model v42hdtv10a)won't turn on. I checked the fuses and found one burnt out on the upper left board (when looking from the back of the tv.) I replaced this fuse (4 amp 250v ceramic)and turned on the unit. Then a loud pop sound and smoke came out. I checked all the fuses again and they were all good. what could have happened? Where do I go from here?
    Sergeant:
  • 226 Answers
Hi, do you know from what area the smoke came from?
4 Amps seems a little high. Sounds like power transistors have blown, maybe even a capacitop or a main filter cap has gone short.
Sorry i can't help much, is there anywhere inside that would indicate a different manufacturer?
Board numbers, chassis numbers , i will try and help.
Regards - Anthony
Posted on Feb 08, 2010
WON TURN ON
For the first step, try using the button on the TV itself.
Secondly, check if the power cord is snug, and not burnt. Sometimes after a blackout, there would be a power surge, and that might burn your plug.
If both doesn't work, the fuse in your TV may be blown, or the Power Supply may also be burnt too. If this happens, you're going to have to hire an expert to help replace the broken parts.
Note that in some TV models, the fuse can be replaced by users. If this is your case, try checking the fuse to see if it's blown or not.
Feb 02, 2014 | Panasonic Viera Tc-p42x5 42" Inch Flat...
My 5 years old Plasma TV found half of the screen picture view not very clear.. The half colour seen blur..
Your Buffer boards or the YSUS main are bad. THe YBU-Y Buffer upper controls the top half of display, the YBL-Y Buffer lower controls the bottom half and the YSUS Main controls both those boards. They are located to the Far Left on and opened Set.
Jun 21, 2010 | Philips 42PF9966 42 in. HD-Ready Plasma...
DELL PLASMA
Most cases the Y-SUS, Y upper buffer, and Y lower buffer is the problem. The replace the 3 boards are located on the left side of the chassis when you open up the TV. 90% of the time this will solve the problem.
Look for burn marks on the upper and lower buffer boards (mostly around the chips with the heatsinks on them).
Apr 01, 2010 | Dell W4201C 42 in. Plasma HDTV
I have a 42" lg plamsa tv the screen went black and still had sound.. found a blown fuse on the board to the right of the power board, when i replaced the fuse,it will power up and then 5 seconds later i...
The fuse you have replaced would have been on the sustain board, now that it clicks indicates a problem either with the control board or the sustain board. You would need to disconnect the connector from the power board to the Y-sustain board (left of power board) to check if the Vs & Va voltages are present, if so then the power supply will be working ok & the problem will be with the previously mention boards. There is the possibility that the plasma display screen could also be faulty.
Nov 06, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
No power
First off I did not see make or model. When plasmas die you have failure in either the power supply of the sustain boards. Do you have any voltage readings from va or vs ?
Craig www.classtorations.com
Jun 08, 2008 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
LG PLASMA 42" TV MODEL: MZ-42PZ14 ABLLKS
Check the fuse on Y Sustain Board. If the fuse was gone, replace that board.
Jan 19, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
Vizio P2 42 in. HD-Ready Plasma Television Logo
427 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
