Keurig B100 Coffee Maker
Problem for Keurig B100 Coffee Maker
Using Burnzy's solution for little/no water
By caffinegirl on Feb 22, 2008
It was great having the picture of the side. But before I disconnect the check valve, I want to make sure I have it properly identified. Is the check valve the clear white assembly that is located below the bent tube out of the tank unit and above the bent tube going into the white/silver cylinder ?
Do I let the pump run the full "cup" cycle before turning it off, to get all the water out of it or just a few seconds?
Being a semi-fixit girl, I just like to make sure BEFORE I dismantle the wrong part. Sorry guys for a probably a "stupid" question.
Best Solution
posted on Feb 23, 2008
Helpful)
Burnzy
Rank: Apprentice
Rating: 98%, 23 votes
My picture had arrows with labels indicating the location of the pump and the check valve, but they disappeared when I posted it. Anyway, It sounds like you have located the check valve that causes most of the brewing problems. The valve is white and semi-transparent with a spring in the middle. When this valve fails, water flows from the tanks and down into the air pump (white/silver cylinder) which disables the pump.
I have repaired three of these now, and two needed new check valves, but only one just needed to be cleaned. I found the valves on ebay for $7.00 (try seller; "Dartbikes"). if you do need to replace the valve, make sure that you purchase a high heat (275+ deg F)rated 1/4" to 1/4" check valve. The new valve will not be identical to the original, so will be adding the valve under the original. This should fix your problem... however, one of the units I fixed had a frozen pump which was caused by the water that got into it. I was able to open the pump and free the frozen parts with silicone, then it worked fine again.
As for your second question, no you don't need to run a cycle or drain it before opening the unit. However, you should unplug the machine to prevent getting shocked. Though, you may need to power in on a few times while it's open to test it. So if you do, don't touch any terminals or exposed wires.
Good luck and let me know if you still have questions, Erik
Was this helpful?
Yes
No
Popular Solutions for Keurig B100 Coffee Maker
Questions and Unsolved Problems for Keurig B100 Coffee Maker
Do you recommend Keurig B100 Coffee Maker?
Answer
Answer
Hi.. I have the single serve model and the start button wouldn't engage the machine this am... what... (More)
Answer
My almost new Keurig (which I LOVE) keeps shutting itself off. I have a reset button on the socket... (More)
Answer
water dispenser gets plugged - won't make coffee - i'm very dissappointed.
Answer
kuerig b100 suppose to be 8 oz cup only 4 comes out?
Answer
Hi, My water heats up but never spits out? please help me.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
