Question about Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump
How to prime a sta rite mse 7 deep well pump, when I've filled the 1 inch pipe plug with water and it won't fill.
    Champion:
  • 243 Answers
Have to fill the housing complete with fluid. make sure there is no more air in it. also make sure that is not poss. to **** air. also the sucktion side must be full of fluid. watch rotation direction. pump is not able to **** from under 7 meters.
Posted on Feb 08, 2010
Where to add water to prime pump ds3hf-01 sta rite
water is filled in the body of the pump to prime it
fill the filter housing if that is part of the pump
make sure that there is no open pipes /hoses or air leaks on the suction side of the pump and that includes any vacuum machine hoses floating on the water surface
Jun 26, 2016 | Sta Rite Pool & Spa
Well pump losing prime
you might have a leak in the foot valve, you can try installing a check valve several inches before the intake to maintain a prime, or check and clean/replace the foot valve.
If the pump ran dry, check the inlet fitting. the pump can get hot and melt pvc piping connected to it, causing air to leak in the inlet side.,
Feb 14, 2014 | PENTAIR WATER Pentair Sta-Rite DynaPro 1HP
Have deep well vetical sta rite pump both pipes in ground staying full of water will not pump press does not looose prime but wont build press
shut off pump breaker at the lowest faucet drain completely. Turn it back on. If this doesn't work, you have to change out the pressure valve on the side of the tank. it's not hard.
Oct 08, 2012 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Prime the pump
see the FIRST in red under the STA-RITEremove the lid fill the pump up with about 3 gallons of water then replace the lid and start the pump. should start to flow in about 1 minute, if not repeat priming procedure
Jul 19, 2012 | Sta Rite Industries Shallow Well Jet...
I have a 1 hp Sta-Rite Centrifugal Pump, MPRA6#-147L. When on, water is coming it but the area with with filter is not filling up. I get no pressure on the filter and very little water is going to the...
CRACKED LID BAD LID O-RING,SUCTION LEAK, OR CLOGGED IMPELLER, LOOK AT YOUR BASKET IF IT HAS CRACKS, CHANCES ARE THE IMPELLER IS GOT **** IN IT. SPLIT THE PUMP AND CLEAN OUT THE IMPELLER , GET A NEW BASKET ASAP.. REMEMBER TO (PRIME THAT PUMP) AFTER ANY REPAIR !!!!
JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jul 23, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
We are renting a house with an in ground concrete pool. Repeated attempts to get the pump and filter going have failed. The pump motor starts but there is no movement from the pressure gauge on the Sta...
The pump does not need to be on during the fill process. You don't need to turn the pump on until the water level gets to the middle of the skimmer. The skimmer pulls water out of the pool to power the pump. It then goes through the filter and out the returns (jets) into the pool. If there is not enough water going to the pump (through the skimmer), the pump will run dry and burn up.
Jun 14, 2011 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
How do you prime a sta-rite mse-6 deep well pump?
Take the pressure guage off and pour water in the hole untill it fills the pump, then screw the guage back on and cranck it up. You may have to do this a few times depending on how deep in the grownd the water is.
Jan 26, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
2 hp vertical sta-rite well pump
Did you prime the pump? To prime: Before turning pump on, unscrew plug cap from top of pump (usually on pump impeller housing,) and with a pitcher or garden hose, fill pump full of water, and replace plug. Then turn pump on and see if problem is solved. If leaking: Are all fittings tight, O-rings and seals new, and is there any pipe thread tape on all threads w/o seals?
Nov 02, 2008 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
Open Questions:
See all Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Questions
Sta Rite Ds3hf 1.50 Hp Self Priming Irrigation Pump Logo
899 people viewed this question
Top Sta Rite Garden Experts
appman67
appman67
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Sta Rite Garden Expert? Answer questions, earn points and help others
