Question about Philips 43PP9202 43" Rear Projection Television
Bad convergence issue and moving TV
Hi, I have a 43" with a bad convergence issue and I need to move it to a new location. I will be moving it in the back of a pickup truck will that effect the tv in anyway or make the convergence issue any worst?
    President:
  • 4,402 Answers
Yes the bumps you go over have a chance in making any connection loose.
Posted on Feb 22, 2008
Hi in the convergence to adjust the color the red is above the plus sign in 3 spots and will not come down and they are not straight
does the blue convergence crosshairs move up and down left and right? Does the red move left or right. does the red move up at all. this might indicate a faullty resistor, bad ic or just bad convergence data. let me know i am here to help
Nov 04, 2010 | Toshiba 43A62 43" Rear Projection...
Will not converge
hello, the convergence ic's have gone bad in your tv . and sometimes they fail because of a 50 mfd @ 50v capacitor by each ic goes bad. if you have the skill at soldiering and desoldiering you may try repairing it yourself otherwise leave it to a qualified repairman. thanks .....techman...580-243-8025
Apr 01, 2010 | Apex Digital GB43HD09 43" Rear Projection...
Red ghost image or shadow
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
rate me
Jun 11, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Ghost letters blue and red
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 09, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Intermittently screen move to one side with distrited picture
Might be the convergence chips. Do you have any problem moving the convergence under the menu setting? Convergence chips are reasonably priced. If you know a friend or someone who can solder better than average, I would go this route. My tv wasn't that bad; I wasn't able to set 2 of the 3 colors during convergence setup. Changing the 2 convergence chips did the trick!
May 24, 2009 | Philips 43PP9202 43" Rear Projection...
Cant figure out how to access convergence
Your TV most likely has failure in the convergence circuits. ( common problem )
  • Screen looks 3D
0667c5f.pngSOLUTION
Apr 19, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Convergence problem
Some how instead of posting this to another persons problem it posted here.Hmm Oh well you said you replaced STKs what was their numbers and you may need Service Code also to Realine convergences
Dec 24, 2008 | Philips 43PP9202 43" Rear Projection...
Resetting convergence daily on Toshiba 43h70
Hi Mark, tough call without putting a scope to the circuit, either the convergence IC`s are going bad, signal from DCU is going bad (digital convergence unit), or possibly bad solder somewhere in the convergence circuit, I`m afraid your going to need a tv tech for that problem, BMW Rider
Jan 02, 2008 | Toshiba 43H70 43" Rear Projection...
Converging green?
jaymz, you can`t move the green, the green tube is always mounted in the middle and is not adjustable from the convergence menu. red & blue should be converged one at a time on top of the green, once you have accomplished this the crosshatch grid will be white and that means your done :)
Nov 30, 2007 | Philips 43PP9202 43" Rear Projection...
Vertical Red/Green lines
You have bad connections on the board and need to be resoldered or the convergence IC's are bad. If you know how to solder on solid state elctronics then you can change the IC's or find a bad connection on the board if you know the High Voltage issues when working on a TV set. If you have to training on TV sets I highly recommend that you call a service person to assist you in this repair.
Sep 25, 2006 | Toshiba 43H71 43" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
