I have a RCA l46fhd37R tv that ocassionally the picture does a wave across the screen. We have tried different HDMI cables with no luck.
Put a magnet on top of screen n check it
Posted on Feb 08, 2010
How do I reset my TH-50PX8OU Plasma TV
hold vol- on on tv and ok from remote will reset
Jan 09, 2015 | RCA Televison & Video
Rca proscan tv 36
PiP shouldn't matter when regarding attaching your computer to your television.
If you have the appropriate cables and ports, such as an HDMI, then you should be able to connect the two together.
I am currently using a television as my main monitor. All I had to do was connect the HDMI cable to each and select the correct input on my TV.
If you do not have an HDMI port on your computer, there should be adapters available.
At the end of the day, the only difference between a television and a monitor is that a television has tuners in it.
Sep 11, 2013 | RCA Televison & Video
RCA L46FHD37R repair
good luck getting parts or schematic for RCA but at least if open set look for puffed up caps on the power supply board like these:
Apr 17, 2012 | Televison & Video
When using PS3 on RCA D52W19 TV, the screen does not fit ( it is zoomed and off-center) in 1080i resolution.
hello!
Have you tried to toggle "format" or "screen size"? On those sets non HD and HD settings could be adjusted separately. Try that, first. If no luck, try similar settings on PS3. I bet, you will be able to match screen format there, as well. To me it looks, like picture formats are mismatched. Also: try to use "component" cables, instead of DVI adapter cable, if nothing works.
good luck,
Alex.
Feb 16, 2012 | RCA D52W19 52" Rear Projection Television
I can not get the pic on the tv
If this is a new DVD player that you have connected to your TV,
It can be connected in three different ways using three different cables.
only one type is required
  • one way is using a RCA cable, which is a yellow plug on the DVD and TV
  • another way is a S video cable, which is round and has multiple pins.
  • and the third way is a HDMI cable which is rectangular with multiple pins
Which every one you use, for eg if you use a HDMI cable to connect it up to the TV you will need to select HDMI on your TV via the remote and press TV/AV until you get to HDMI.
Also most DVD players have a menu to set up, which you can select what type of output picture lead you are using, Eg. HDMI or Composite = RCA or S Video.
I have enclosed a picture to determine which lead you are using.
If your TV is HDMI then this will give the best picture quality then S Video then composite RCA.
I hope this helps you
MobileJB
Jul 15, 2011 | Panasonic DMP-BD30K Blu-Ray Player
I tried hooking up my laptop to my 37lh20 tv. I connected the avi to the pc input and an audio cable fro the headset jack on the tv. If I put the tv input on rgb pc I get the picture but no sound and if...
Unless you hook HDMI to HDMI, you won't carry sound across the HDMI cable. If you're using a VGA to HDMI converter, you'll get the picture but no sound.
I have a feeling the headset jack on the TV is an output rather than an input. Most TVs accept HDMI, RCA, or a digital audio input (either coaxial or optical). Unless you have a S/PDIF optical output from your laptop (and you obviously don't have an HDMI output), then your only other choice is likely to get a cable that splits a 1/8" headset type connector into two RCA plugs that you'll plug into an AUDIO IN input on your TV.
Jul 14, 2011 | LG 37LH20 37 in. LCD HDTV
I set up teac HDB840 to tv- via coxial cable from wall to set top box, then rca cables output of set top box , then to input to tv.-tried av button on tv showing av1 av2 and av3 but still no picture only...
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
Jun 18, 2011 | Televison & Video
Turned on the tv and i have no picture just sound...
Most likely fault is the backlight inverter board. May be a simple fix due to bad capacitors or may require a new inverter board.
You can check that the LCD screen is still working by shining a torch on the screen and looking carefully for a dim picture. Try putting the menu on so that you have a known static image to look for.
Feb 11, 2011 | Sanyo DP46849 46 in. HDTV
RCA l42wd22yx5 green screen when on HDMI... Still get sound
We had the same problem. What we did was unplug our DVR box from Comcast to reset it and plugged it back in and the picture came back.
Dec 05, 2009 | Televison & Video
If I tap the rca jacks in the back the screen gets distorted
You need a hdmi connector from your tv source to the TV. RCA connectors don't have the capability for HD signal transmission. You can use them for a connection but the picture will be fuzzy if trying to watch HD signal. Check your cable/dish box to see if there is a hdmi output. If so, buy a hdmi cable & that should solve your problems.
Mar 19, 2009 | Akai LCT4216 42 in. LCD Television
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
