Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune mode # MAH500BWQ Sqeaking or grinding sound at each initial start during the washing cycle
Rotu
  • 175 Answers
SOURCE: Whirlpool Calypso Washing Machine
How old is this product? I have a friend who is an authorized whirlpool servicer, and they won't even work on them. Supposedly they are a bear to take apart, and have a very bad tendancy to flood. Check into it, but he tells me there is a class action lawsuit against whirlpool for these. This is 3rd hand information, so you will need to verify if this is true or not.
Posted on Oct 05, 2006
SOURCE: MAYTAG WASHING MACHINE
The rubber smell is the belt from the motor to the tub. The grinding sound is/was the tension pulley that keeps the belt tight. The bearing on the pulley probably went out and now the belt is burning because of the friction of sliding around the pulley. The belt and the pulley need to be replaced. If you have the room, turn off and disconnect the hoses. Unplug the electrical cord from the wall outlet. Remove the drain hose and any water in the tub. Carefully tip the washer over backwards, DO DROP IT!!! Now you should be able to see the motor, tub, tension pulley, and belt. With a basic 3/8' drive socket set, probably metric, and a couple of screw drivers you should be able to remove the belt and the pulley. Take the belt, pulley, and model numbers to an applicance parts store and buy replacements.
I only suggest this because I hate paying labor. If you are not machanically inclined then you are going to have to pay the labor.
Good Luck
Posted on Dec 19, 2007
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Posted on Dec 06, 2008
huuum
  • 750 Answers
SOURCE: Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Posted on Apr 03, 2009
SOURCE: My Maytag Neptune washer won't spin during the spin cycle.
I'm having the same problem...Does it say LR?
Posted on Jul 20, 2009
I have a loud grinding noise during the spin cycle on a FAV6800AWW any help please
sounds as if it could be the bearings,have it checked out by your local service engineer
Jul 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune TL ( purchased in 2005) is grinding during the wash cycle only. Spin cycle is quiet. Once the entire wash/rinse spin completed I opened the washer to retrieve the load and found a piece...
Jose,
I'm an owner of three FAV6800A machines and I'll respond to help because you want to roll up your sleeves and try to save your $1K machine.
1st No direct links Google this Neptune TL Washer FAV6800AWW
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with.
Post in that forum your machine Model which I assume is an FAV6800A (LED Console) or FAV9800A (LCD Console)
Include the first two digits of you machines model number. That is the series of your machine.
Give a description of the issue as you did here. I hope the grinding is during wash/agitate if so it may be something as simple as tumbler removal to clear out debris. If the grinding is in Spin Cycle it could be a bit more work like Outer Tub bearing failure.
The Forum in my opinion is geared more toward the DIY owner as I am and as you sound. The forum is free like this and my support is free..........Good Luck D*ick
Mar 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
Jun 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune tl makes grinding sound and stops at 33 minutes in normal mode and at 24 minutes in quick wash mode
Hello djlampl,
With the lowest spin cycle setting I enter spin cycle in Quick Wash around the 21 minute mark. But first question is do you hear the grinding noise with the tumblers rotating during the wash/agitate cycle?
If you start a spin only cycle do you hear the grinding noise?
Does the washer error code out with an error code to the display? Codes such as dC, uC, Lr?, I assume the machine type is a FAV6800AW is that correct?
Any additional info will help in troubleshooting…..Rich
Assuming the machine type is a FAV6800A/FAV9800A here are some handy links;
The Service Manual for reference. Sears Parts Direct for reference.
Nov 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hgd76
Jun 26, 2009 | Maytag Neptune Washer
Loud noise
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Loader Washer
Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
Dec 29, 2008 | Maytag Neptune Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
