I need someone to feel the top of the compressor. Is it cool, hot or too hot to keep your hand there? Usually on GE models like yours the=> WR55X11072 Main Control Boardis the problem along with the start relay, overload and run capacitor. GE Refrigerator Model GSH25JSDD SS Parts
I'm here should you have question, Thanks, Sea Breeze
you have a bad computer board located on the back outside wall,part number wr55x10942.everything runs through the board,sometimes you'll notice that the fans aren't running correctly too.unplug the machine,remove the cover,you'll need a pair of needlenose plyers,there are 4 white plastic pins that hold the board in place,pich in the tab on the pin and pull on the corner of the board,pull off the wire harnesses and plug them back in the same connectors then ground it with one of the screws.go here 801 is your part and this is your problem http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Refrigerator-Parts/Model-GSS20IEPCCC/0432/0165000/G3090022/00008?blt=06&prst=&shdMod=
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
It can take a few days to level out properly...
As the weather is getting warmer for many people their freezer and/or
refrigerator do not work right because of a dirty condenser coil...there are
also many other things that can go wrong. If you are hearing a clicking or
buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start
trouble shooting your unit...and something that you can do rather then calling
a repair person to do a simple thing for you...
replace the ptc overload relay on the compressor,(its running on the start windings and not the run windings and not getting into the full run mode),they just unplug and plug into the compressor side and are relatively inexpensive
On my GE side by side (model GSS20IEMDWW), the evaporator coils froze over due to constant running of the compressor. The compressor was constantly running due to a faulty temp sensor in the fresh food side of the unit. The sensor was apparently reading too hot, thus never signalling the computer that it should stop trying to cool.
This could be what the original poster was attempting to describe.
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
