Question about Sony Playstation 3 (PS3) Console
I just connected my PS3 with an HDMI cable. Now the screen will black out during the game for a few seconds. Sometimes it will not happen for an hour or more. Other times it happens every few seconds.
    Scholar:
  • 130 Answers
Sounds like a bad HDMI cable or a bad HDMI port. Swap HDMI cables first to see if that fixes the problem.
Posted on Feb 08, 2010
I have a PS3 hooked up via hdmi. The screen goes black for 1 second then comes back during game play. It doesn't do this when hooked up through component connections. I replaced the hdmi cable and...
Ur tv is on 3D mode setup probally,i'm wright?Yes?Set the tv it back to 2D mode,should stop the tv delaying 1 sec. black out intervolt should stop happening.Because ur are not using a 3D PS3 machine ur are using an PS3 2D a normal system.
Aug 08, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
When playing regular dvdson my ps3, the screen will sometimes go black for just a second or two then come back on. I sometimes notice a red or green flash of color right before the pic goes out or comes...
Ok I have had this happen a few times before. What I do to fix it is disconnect the HDMI cable while everything is still on and playing and then re-insert the cable back into the TV. This re-configures the HDMI signal and should hopefully stop this problem.
Hope this helps and thank you for using FixYa
Aug 31, 2010 | Sony Playstation 3 (PS3) Console
MY PS3 DOES NOT SEEM TO BE WORK WITH THE HIGH DEFINITON CABLE IT CAME ON FORA FEW SECONDS THEN SCREEN COMES UP WITH NO SIGNAL????
This usually happens when you first buy your ps3 and try to use the HDMI connection immediately. The problem is that the ps3's default output resolution is set to 480i out of the box, and when you try to use an HDMI connection first, HDMI can't do that resolution. HDMI only does 480p, 720p 1080i and 1080p.
See :)
This also happens if you move your ps3 a lot. As it is, HDTV's are either 1080p (full HD) or 720p (including 1080i). If, for example, your tv is 1080p, when you set your display settings in the ps3 menu, it will set your XMB, or ps3 main menu to the max resolution of your tv, 1080p in this case. The resolution will automatically adjust when you start a game, and that game has a native resolution output. That's why, most of the time, games will play in 720p, because that's there native, or original, resolution. This is also the reason why sometimes people have no display on there TV, or a black screen, and when they play a game, that will actually display. That's because your tv can ACCEPT that resolution of that game.
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
Ps3 goes to black screen while playing
try another game.if it does that during the other game then it's the ps3.but if it doesn't then it's the game.
Mar 26, 2009 | Sony PlayStation® 3 (60 GB) Console
PS3 won't connect to TV with component video.
You need to connect the PS3 to the television with both connectors (HDMI and Component). Then in the display settings change it from HDMI to component and during the 30 seconds that the screen goes black you need to disconnect your HDMI cable from your playstation. Then switch to the input that the component cable is connected to on your television (ie. AV1, AV2, etc). From here you will see the countdown for the test and you can continue with these settings.
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
During DVD movie playback, screen goes black periodically
it could be that the disc is and ordinary dvd disc and cannot stand the capability with a high def tv because i have the same problem and when 1 put a bluray disc in its fine
Mar 10, 2008 | Sony Playstation 3 (PS3) Console
Ps3 video and audio comes and goes
TRY playing game using standard line input cable and see if there is a difference
Jan 27, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
64 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
