Question about Grohe 27007000 Chrome Freehander Freehander Three Function Double Shower He
Hi there, I have a 27007 Freehander that was just installed by a plumber. When I turned it on to test, the right hand side of the swing arm, pulled away from the mounting assembley, and water shot up through a little hole on top of the mounting block. Is this a defect, or fixable? thx jeff
    Scholar:
  • 81 Answers
Without being ther and seeing I ofcourse can't be sure but based on what you have told me I would lean towards defect. There is no such thing as perfection in any assembly line. It's not ever easy to block water under pressure from coming from a place it was not designed to come from
Posted on May 29, 2010
Attach bagger to john deere d140
While standing at back of mower with the bagger hood in your hands. The black support arm is hanging down, positioned at the back of the mower. At the bottom of the black support arm are two tangs with a gap between them (gap is 2"-3"). The tangs will be inserted into two slots on the towing frame. That is the black panel of the back of the mower. They will not be centered; rather they will be offset to the right side of the tow frame, about mid way up the back.
Lower the hood support so the tangs are horizontal, or parallel to the ground. Once parallel to the ground they will slide into the slots. After they are in the slots, while holding the black support arm steady, raise the two swing arms up to the seat. After raising the swing arms (light brassy color, V shaped connecting rods) then raise the black support arm with the tangs held in the slots. As you raise the black support arm vertically the swing rods will move forward, over the top of the fender, and align with two retaining holes.When the hood is level with the top of the seat you will be able to insert the ends of the swing arms into the holes in the fenders. This will complete installation of the support for the bagging hood. Now follow the locking instructions below.
Note: prior to starting this procedure you may have to remove a spring clip and locking pin (about 6" long and 1/4" round) that runs through the black support arm. It runs right to left through two holes in the support arm, the spring clip locks it in. This pin may be supplied uninstalled. The function of the 6" locking pin is to keep the swing arm in the fender holes after you have everything in place. It must be removed to perform the above installation. After the installation is complete insert the lock pin, right to left, pointy end goes in first, above the swing arms where they meet the black support arm, then insert the locking spring clip in the tiny hole of the locking pin. This locks the swing arms in place.
Oct 12, 2014 | John Deere Garden
Excercise bike clunking noise
please follow this steps and fix it. God bless you
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Nov 26, 2013 | Nordic Track Exercise & Fitness
Machine is Quivering while excersisng
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Lubrication
Drive Belt
Nov 13, 2013 | Sole Fitness Sole E55 Elliptical
Quivering while excersising
I have a Proform Smart Strider. We just assembled it & when I tested it there's a very loud scraping sound when I stride, regardless of the level or program...help, pls. Thx.
I recomend you to disassemble again, and repeat the steps. Something must be there ARE not according with the instruction assembling. Try however for to see the some loose parts, bolts, nuts, and lube.
See this small instruction.s
God bless you
Lubrication:
Oct 15, 2013 | Proform Smart Strider SpaceSaver...
The wheel on my elliptical is stuck. A couple steps and it got stuck. How do I fix that?
see this causes and fix it. God bless you
Lubrication
1 Drive Belt
Oct 14, 2012 | Exercise & Fitness
Bremshey (Tunturi) Orbit Control S elliptical belt alignment
Dear Si: Please do the following>
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Remove the bolts connecting the swing arms to theelliptical's upright. Detach the swing arms from the upright, then spread alayer of machine grease over the axles on the upright. Reattach the arms to theupright.
sincerely.
ernesto cuadra
managua, nicaragua. c.a.
Feb 12, 2012 | Exercise & Fitness
My Pro-Form 330 elliptical has a resistance problem--it won't adjust and it seems to be set on a difficult resistance, I can't really pedal it. how do I fix this? I tried switching the levels, but...
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 27, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
Rear wheel removal on yamaha cygnus
Everywhere I read is wrong. For Yamaha Cygnus-X 125cc rear wheel removal
It is removed from the right hand side. Do not start dismantling the gear box side !
Remove 5 bolts of exhaust. Careful don't loose exhaust seal where it connects to engine. You may need friend to lean the bike over to access bolts underneath.
2. Remove main 24mm bolt on axle
No need to loosen brake !
3. Remove 3 bolts holding swing arm. That's the big triangular bit.
4. Pull off the swinging arm and on axle is special shaped washer. Note which way it comes off.
5. Pull off the wheel leaving brake shows behind.
Jul 13, 2011 | Yamaha PowerMax 150 GP1 Motorcycles
Freehander leaks at shower heads
Hi
Thank you for your query
If you just grab the showerhead with one hand and then unscrew anticlockwise the pipe underneath it should just screw off, once this has been done simply replace the O ring and rescrew
I hope this has been useful
Mar 14, 2010 | Grohe 27.007 FreeHander Shower Head Shower...
Grohe 27007000 Chrome Freehander Freehander Three Function Double Shower He Logo
451 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
