Question about Mitsubishi Televison & Video
Our tv's volume stopped working - Mitsubishi Televison & Video
  • mijaresmary Feb 08, 2010
    is there a muting on off on the tv
    is there a muting off/on our tv...that controls volume
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please reset the TV by unplugging the power cord for more than 4 hours and plug it back in. Now check that the sound is coming normally from the set. You’ll need to also check these parts---Breakdown or overheating of some components of amplifier, wiring, speakers, function settings, power supply and sound detector inside the signal IC processors are fine. Go to the on-screen-display and make sure you are set for stereo audio. Please check that the on screen display is set up for internal speakers and stereo audio. Also, check any other settings that may have gotten disturbed accidentally. Make sure that all the settings are correct and that the internal switch on the back is set right. Use headphones and check if you’re getting sound through them. You’ll need to check that the issue is with the speakers, wiring or the amplifiers.
If still the issue is not resolved then check the audio chips are fine. If you’re using RCA cables then switch to HDMI and vice-versa. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 08, 2010
  • Rylee Smith
    Rylee Smith Feb 08, 2010
    Nope, you can try to unplug the TV and then plug it back after 5-10 minutes so that it resets itself. lease do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    This rating is not acceptable. I have already advised you of the procedure what needs to be done with the TV. Please change the rating.
    Thanks
    Rylee
Sony Bravia 55'inch led volume controls stopped working. Remote or tv button don't adjust volume
Volume is controlled by the main board. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy and fix it yourself. It's easy.
May 10, 2017 | Sony Televison & Video
After switching off and on last night the volume and mute on stopped responding on Humax remote. IT is PVR9150T and remote RT531B. TV Remote works fine with volume. Humax remote works fine on all exce
Note that this type of device is designed to be left on at all times, so should not be switched off each night. I suspect that it has some slight corruption in the user-settings, so a factory reset may be required.
Apr 03, 2014 | Humax Televison & Video
Volume not working on Hitachi L42s503 TV
Is the sound ok and you are not able to control the volume from the remote?
Aug 04, 2012 | Hitachi L42S503 TV
I have a 52" mitsubishi
go into the menu and go to audio/video should be able to set your audio from there
Dec 11, 2010 | Mitsubishi Televison & Video
Symphonic volume on my tv stopped working i have
Hi
can sound be heard from headphone socket when a headphone plug is inserted if so headphone socket is faulty or the lound speaker,
Mar 14, 2010 | Symphonic ST419E TV
42 in Vizio TV volume stopped working
you can eithor get the board from shopjimmys.com or hook up surround sound system-and not use tv speakers
Sep 11, 2009 | Vizio L32 32 in. LCD HDTV
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Volume on tv stopped working
HIT MENU, GO TO AUDIO (SPEAKER PIC) SCROLL DOWN TO "2ND PAGE" AND SELECT SPEAKERS ON. AND YOU MAY NEED TO ALSO SELECT SBS ON
Jul 16, 2008 | Toshiba 36AF42 36" TV
Hi there!
I think your remote may be at fault. Liquid spill or sweat from the hand accumelates on the inside over some time and then becomes sticky. Some of the buttons may be permanently activated. Then other functions won't work. Have someone check it for you or if familiar yourself. Regards, JUS004
Mar 12, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
190 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
