Question about Akai PT5492S 54" Rear Projection Television
Model # PTH5498 Red and Green horizontal lines show up after the set has been on for a little while. They don't stay but come and go
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 88 Answers
If it is being fed by a component video source you could have a loose connection. Component sends analog video signals via Red Green and Blue cable. If the blue cable is loose then you will generally get a redish or greenish looking picture. If the cable isn't the problem try using a different input such as the S video input. If this still doesn't fix the problem then you could have a problem with one of the lamps most likely the blue. Hope this isn't the case for you though.
Posted on Feb 08, 2010
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    How do you set convergence
    What is your Make and Model number?
    Mar 18, 2010 | Televison & Video
    Epson PowerLite 83+ goes completely green or red
    make sure the signal matches. you could reset the settings to factory default.
    Nov 10, 2009 | Epson PowerLite® 83c LCD Projector
    RED TINT
    yOUR CRTS ARE SHOWING THE SIGHNS OF WEAR. ON THE FRONT OF THE SET BEHIND THE SPEAKER GRILL OR FRONT FACIAL. THERE ARE 6 CONTROLS 3 FOR SCREEN RED GREEN AND BLUE AND 3 FOR FOCUS RED GREEN AND BLUE. YOU CAN TRY TURNING THE RED SCREEN DRIVE CONTRIL COUNTER CLOCK WISE. JUST A VERY LITTLE BIT.
    Jan 22, 2009 | Televison & Video
    54" Projection TV
    Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
    Aug 28, 2008 | Akai PT4298HD Rear Projection Television
    Convergence adjustment
    HELLO . it sound like you need to replace the convergence board or just the IC'S ON THE BOARD. IT WOULD BE CHEPER THAN THE HOLE BOARD. "GOOD LUCK"
    Jul 27, 2008 | Akai PTH5498 54" Rear Projection...
    Convergence not lining up
    Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
    Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
    Akai PT5492S 54" Rear Projection Television Logo
    50 people viewed this question
    Top Akai Televison & Video Experts
    Jaime Hernandez
    Radames Pagan
    Radames Pagan
    Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
