Question about Samsung SyncMaster 753 DFX 17" CRT Monitor
Red color channel is missing - Samsung SyncMaster 753 DFX 17" CRT Monitor
  • 922 Answers
Check the monitor cable for missing or bent pins. If you find any bent pins try to carefully bend them back. If they are broken or lodged in the computer or monitor plug you may have to replace the plug.
Move the cable around while the monitor is on to see if moving the cable has any effect on the color. This will indicate if there is internal damage to the cable. Internal damage will require professional repair.
If you are still missing the red channell no matter what you do with the cable the problem is likely to be in the monitor which will need professional repair.
If you want to make sure it is the monitor, not the computer, with the problem try using another monitor.
Please vote for my solution if it helps.
Posted on Feb 08, 2010
Sony klv32Bx350 red colour missing
Please Do the following steps to get a solution.
Reset the TV to the Factory Default mode. and play a high contrast RGB color flashing flashing video through USB.
It could solve your red color missing problems.
if not solved then ask a technical expert.
Thanks.
Aug 17, 2017 | Sony Televison & Video
How do I reconnect using black & grey cables?
The colors of the cables are just so you can tell them apart. The standard color coding is RED is right audio channel and White is Left audio channel. Just make sure that whichever color (black/grey) you use the same color end is right channel on both or left channel on both.
Oct 11, 2015 | Onkyo Rc-251s Tx-sv303 Tx-sv313...
Missing red composite signal on panasonic pt-47wx52cf
Check your jacks and cables.
The RED jack is either (1) left or right channel AUDIO signal or (2) the RED color channel of an RGB (Red, Green, Blue) COMPONENT video signal.
Yellow is the COMPOSITE video signal.
Dec 31, 2012 | Panasonic PT-53TW54 53" Rear Projection...
My Vizio 32 inch HDTV picture colors are all off. I have tried to adjust the tint/colors but the overall picture colors are all off. It is as if some of the primary colors are missing.
Maybe if you are using component input wires, one is not inserted fully. Set color to max and put tint in the center, then flip channels and look for known solid colors items of red, blue and green. You can see when one is missing, as a mixed color will just look odd, but a true r,b or g will just not be there so to speak. Hopefully is might just be a feed wire in, but be careful, as too much pressure on insertion can crack a solder joint inside the set.
Nov 26, 2010 | Vizio L32 32 in. LCD HDTV
The tv screen color is red no matter the color adjustment
hello, Confirm that the source is not a weird color video - try another channel or a tape. Verify that this is not a missing color problem - one of the primary R, G, or B, has disappeared. If so, refer to the section: Intermittent or missing colors. Once these have been eliminated, you are left with the following possibilities: Defective part around the chroma chip/circuit. Misadjusted color oscillator. Bad connections or short circuit in area of chroma chip/circuit. Defective chroma chip (don't suspect this first just because it is probably very expensive). Bad degauss circuit resulting in lack of degauss or abrupt termination of degauss current rather than smooth tail off. The CRT is not being properly demagnetized and color purity is totally messed up. Bad CRT - the shadow mask has been damaged and it is impossible to properly adjust purity across the screen. NOTE- This will require a skilled personnel to handle this
May 19, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Black and White Channel
Check the fine tuning for that channel.Adjust + or - accordingly, see what happens?
Oct 02, 2009 | Apex Digital AT2708S 27" TV
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
Samsung SyncMaster 753 DFX 17" CRT Monitor Logo
195 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
