Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE profile side by side making loud popping sound evey 5 minuntes (pop, pop, pop)coming from bottom section of refriderator..
5 Suggested Answers
  • 36 Answers
SOURCE: AMANA REFRIGERATOR MAKES A LOUD POP!
Dear Customer
Please perform the following
If it's cooling ok, they're probably normal sounds. Modern refrigerators can make many noises, most people aren't home long enough to hear them. A popping sound could be defrost water hitting a hot defrost element, or refrigerant making noise in the cooling lines. If it's working ok, ignore it. Please rate this,Thank u
Posted on Dec 17, 2008
  • 153 Answers
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
Posted on Jul 21, 2009
aasc
  • 1606 Answers
SOURCE: GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Posted on Sep 30, 2009
DeBruce
  • 145 Answers
SOURCE: Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Posted on Mar 05, 2010
GE Profile refriderator PSC25MSWA is frosting/icing on bottom of Refriderator side
Try defrosting entire unit. Put all food, freezer and refrigerator sides in coolers with ice. Unplug unit and wait at least 24 hours for unit to completely defrost, if neccessary open doors, plug unit back in and see how unit functions. By doing this lines that carry freon should become unclogged.
May 05, 2014 | GE GSS22SGM Side by Side Refrigerator
I have a GE SS25ksta side by side refriderator. The ice maker makes ice, but the chute jams without fail. It is almost as if the ice doesn't weigh enough to push open the flapper arm at the bottom of the...
there's a solenoid that opens and closes the shute or the flapper.the part number is WR62X10055 and it's around 25 dollars.check around the plastic frame that holds this section of the dispenser in place,i'm pretty sure the frame pops off,you might need a putty knife or thin screw driver to pop it off,then you can get at the rest of the parts to change out the solenoid.it's self explanatory and easy to change it out once you pop off the outside frame piece
Jan 16, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
GE French door fridge problem. When you close one door the other door pops open alittle most of the time. Is this normal on french door fridges?
Hello, In a word, Yes. It is totally normal, when you close a door it pushes air into the unit and depending on how it is closed the other door will "pop" open slightly from the "push" of air. Thanks for coming to fixya. macmarkus :)
Jun 20, 2010 | GE Profile 20.7 Cu. Ft. Side-by-Side...
Loud clicking soun when ice maker is dispencing ice
I have this refrigerator and have the same problem of a loud popping sound emitting from the icemaker. It is caused by ice cubes becoming stuck between the mechanism and the side of the icemaker. I think it is just poor design. See photo. e7f283a.jpg
Jan 03, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
GE Profile Knocking
Unplug and closely examine the area for a loose fan blade or anything that may be causing the noise. Better now than to get damage that could be prevented. Let me know what you find, Thanks, Sea Breeze
Mar 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice Dispenser on GE Profile PSS23MSTC does not work.
sounds like the ice is stuck together and the auger can't turn. remove ice tray and dump old ice new cubes should begin falling into tray after 30 minutes or so.
Jan 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Aug 25, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
191 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
