Question about Kitchen Ranges
I NEED TO KNOW WHAT RESISTANCE READING THE OVEN PROBE @ APPROX. 75 DEGREES
    Sergeant:
    Champion:
  • 263 Answers
Error code 000f
Use a multi-meter to check the ohm's resistance of your temperature probe: should be 1100 ohms at room temperature = 72 degrees F. Range Stove Oven Temperature Sensor 12001655 Multimeter DM10T
After time, the connections between the temp. probe and the control board usually benefit from being disconnected and re-connected to keep corrosion from interfering with the resistance redings the control "sees" from the probe...
Jul 11, 2016 | Jenn-Air Ovens
I cant get my oven to stay on model # FFEF3015LSM after a few minutes is turning oven on, it starts to beep and screen says F30
It looks like the probe is the same as the temperature sensor.
On some models, you can recalibrate the oven control up to 35 degrees Fahrenheit higher or lower. Refer to your owner's manual for instructions on how to recalibrate the oven control.
Since you're getting an error message the following may apply:
OPEN PROBE CONNECTION
1. (F30 or F31) Check resistance at room temperature & compare to RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
SHORTED PROBE CONNECTION
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector. .
Possible Replacement Part:
http://www.repairclinic.com/PartDetail/Frigidaire-Range-Stove-Oven-Temperature-Sensor/316490000/1197392?modelNumber=FFEF3015LSM&fromRepairHelp=True&ss=a13b2d1284938
Mar 24, 2016 | Ovens
F3 code on Kenmore Oven Model 911 4558810
The F3 error code indicates that the EOC (Electronic Oven Control board) senses a problem with the oven temperature sensor. You could have a defective sensor, a failed EOC or a bad wiring connection between these 2 components.
Normally, a technician is needed to diagnose and repair this type of failure. The technician would unplug the range and access the EOC in the console. He would pull the 15-pin plug from the EOC and measure the resistance between pins 12 and 13 of the plug. This would check the temperature sensor and connecting wiring. The tech should measure about 11000 ohms at room temperature (75 degrees Fahrenheit).
If this reading is good, the EOC would be the failed component and would need to be replaced.
If the resistance reading of the sensor circuit is bad, the reading would be taken directly from the leads on the temperature sensor. If the resistance reading taken directly off the sensor is bad, then the temperature sensor has failed and would need to be replaced. Otherwise, the wire harness is the failed component.
If you have a volt/ohm meter and the technical expertise to safely access and test internal components of your range as described above, you may be able to diagnose and repair the range yourself.
Feb 18, 2013 | Kenmore Ovens
Code reading is F 30 and oven not working
F 30 - Open probe connection.
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Hope this helps.
Jul 26, 2011 | Ovens
What does the code F1-1 mean on Jenn-Air downdraft model?
If you see the F1-1 error code, I recommend that you continue to use the Quick Test to display the temperature sensed by the probe in the oven. If that temperature is way off, I recommend that you shut off the house circuit breaker for the range and check the resistance of the oven temperature sensor probe. The second image below shows how to access that component. Measure the resistance of the sensor with a volt/ohm meter. It should measure about 1100 ohms at room temperature (75 degrees). I provided a temperature/resistance chart in the first image. If the resistance of the probe is bad, then you will need to replace that component (part number 12001656).
You can order parts from the Sears PartsDirect website. If the sensor probe is okay, you will probably need to replace the control board in the console. I recommend that you have a service technician replace this component.
Hope helps.
Jun 12, 2011 | Jenn-Air Ovens
I have a Kenmore smooth cooktop electric range. It is about 3 years old. Recently i used the self clean function, and since then I can't get the oven door to unlock and I'm getting a F5 code on the read...
Press the "Off/Clear' button to cancel anything on the display, and reset the oven. This is a soft reset and will simply get you out of any program you have started. If the problem still persist,
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the oven back into the wall power supply to reset any anomalies with the oven memory.
Mar 02, 2011 | Kenmore Ovens
The oven doesn't come close to keeping a REASONABLE temperature. It fluctuates sometimes 75-100 degrees. I'm not talking about opening the door and then waiting to re-establish the temperature it was set...
If you just bought it, have it replaced, or repaired under warranty. If it is an old oven, replace the temp probe first (if it electric) It senses the temp inside oven, It is the least expensive part of the fix. If that doesn't work, replace thermostat/temp control board. When you replace a board, you replace the probe too. It will be needed either way. If just changing the probe works, you saved yourself some money.
Apr 06, 2010 | Kitchen Ranges
Digital oven temperate is wrong
Yes, that is the probe that sends info to the controller.
If it's not bad, then the controller is, but normally it's the probe.
Check that the controller has not been incorrectly calibrated before you change the probe out, although most do not allow a swing of more than 15-20 degrees. Yours may allow more though.
I am guessing you measured the actual temperature, to the set point temperature, with a know good thermometer.
Jan 30, 2009 | Frigidaire FGB24S5A Gas Single Oven
F-3 error code
F3 indicates a failed oven temperature sensor. Your model number indicates that your range is manufactured by Roper. They recommend measuring the resistance of the oven probe (at room temperature). It should read approx. 1100 ohms. If the reading is bad, replace the oven probe. This is a repair you can perform yourself. The probe is mounted on the back of the oven wall in either the upper left, or upper right-hand corner. The part number is 252618 and costs (like you said) about $73. If you need guidance on how to remove/replace or measure, let me know. I hope I do not insult your intelligence. I generally ask, because some people are not savvy when it comes to electronics. I hope this information is helpful.
Jan 29, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
